400 sel engine problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-09-2008, 12:32 PM Thread Starter
Date registered: Mar 2008
Unhappy 400 sel engine problem
I have a 93 400sel that has 147000 miles and a good service record.Last Monday i was climbing a hill to my house and she began to loose power.When i stopped to open the gates the car cut out and would not start.just clicking sound.I called a friend of mine and we initially thought it was the starter motor.He manually turned the engine then placed a strong battery into the boot and it turned over but would not start,there was a knocking sound from the engine on the right side.
the car did not overheat while i had it and there was plenty of oil in the engine.i was told that the chain probably jumped the cog and that the engine is badly damaged.Someone else told me that the same thing happened to him with his Merc and he simply changed the rails,chain and tensioners and it was sorted.
Could anyone throw some light as to what has happened and the best way forward.
I do not want to scrap the car.
I figure I have come to the best website for advice.
Any help would be greatly appreciated.
Macmori is offline
post #2 of 3 (permalink) Old 03-09-2008, 01:00 PM
Date registered: Jul 2004
Quoted: 265 Post(s)
It's a plausible explanation but it's not necessarily badly damaged from jumping a tooth or two. But you need to get the valve covers off to have a look. You should also read the fault codes on the 38 pin connector. If the timing chain has jumped you probably also have a broken chain guide or two, and have will chain guide debris in the oil pan.
deanyel is online now
post #3 of 3 (permalink) Old 03-09-2008, 01:48 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 545 Post(s)
Yes, either start tearing it down to have a look, or have the car towed to someone who can do it for you. There is no other way to effect a diagnosis.
GeeS is offline
    93 400 SEL Transmission Problems jsg W140 S-Class 4 06-27-2007 03:17 PM
    400 SEL Pricing - long.. jagbuff W140 S-Class 8 01-10-2006 01:02 PM
    400, 500 and 600 SEL 230emercedes General Mercedes-Benz 6 09-19-2005 01:04 PM
    My dad's 400 sel CaseMan W124 E,CE,D,TD Class 2 05-21-2005 08:13 PM
    400 SEL Questions CDNC36AMG W140 S-Class 2 09-14-2002 09:27 AM
