Squeeky wheel get the grease? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-07-2008, 05:19 PM Thread Starter
Date registered: Mar 2008
Vehicle: 2000 E 320 W210
Cool Squeeky wheel get the grease?
The steering wheel of my 2000 E320 squeeks substantially when I turn it. Is there a way to lube it and quiet it down?
Justaman is offline
post #2 of 3 (permalink) Old 03-07-2008, 05:43 PM
Musikmann's Avatar
Quoted: 5 Post(s)
See your other thread. The steering wheel issue is the only one of the three where I stand on firm ground. Luckily, my car was under warranty but I told you exactly what the dealer did, except for a front end alignment once they reinstalled the rack & pinion.
Musikmann is offline
post #3 of 3 (permalink) Old 03-08-2008, 06:16 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
There are actually TWO tsbs for steering wheel noise, one of which -- the one MM references -- requires removing the rack. The other is a lubrication procedure on the rubber seal through which the steering column passes from the passenger to the engine compartment.
The latter is cheap. The former is stunningly expensive. Mine required both (then under warranty). Recently it's started a light moaning when cold, I'm hopeful it's the cheap procedure.
FWIW, there is a forum specific to your chassis, scroll on down and you'll see the W210 forum in the sedan section. Lots of great tips, DIYs, and folks to give you a hand. You're likely to get better assistance and more pointed information there than in this general forum. Also, please take a moment and complete your BW online profile re: vehicle and location as that can be very useful information.
Take care and enjoy the ride,
Check Codes is offline
    Squeeky Steering Wheel JoeRose70 W210 E-Class 12 01-05-2007 11:34 AM
    squeeky steering wheel? bighamsterneck W163 M-Class 2 11-21-2005 10:52 AM
    Squeeky Steering wheel olivengco W210 E-Class 5 12-16-2004 10:52 AM
    Wheel bearing grease question Jim G. G-Class 4 03-24-2004 08:51 AM
    Front wheel ball scraper/swiper grease seal for 460 Thomas Schumacher G-Class 8 08-10-2002 12:46 AM
