will not start - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-25-2008, 03:15 AM Thread Starter
Date registered: Feb 2008
will not start
hi all
i have an '83 mercedes 240d (sedan)
the other day i began having problems starting her when she is cold. the engine rotates, but will not start. after four or five times she starts, when engine is warm starts fine as well. i checked and cleaned battery connections, and the battery is new.
any suggestions?
my glow plug light comes on as normal, but maybe they need replacing??
could my drive belt have anything to do with this? i had an pretty bad oil leak for a while and i know it leaked all over my drive belt. . .
when it does start there is a puff of white smoke and it sputters briefly
thanks =)
mauisanna is offline
post #2 of 4 (permalink) Old 02-25-2008, 04:43 AM
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 1998 E320 Wagon
Quoted: 26 Post(s)
Sorry, I don't have an answer. You might also want to post your question on the W123 subforum. More people who are knowledgeable about your can might see it. Good luck.
RichardM98 is offline
post #3 of 4 (permalink) Old 02-25-2008, 05:38 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
First - do not ever use starting fluid.
Second - do a search - lots of good info. Things like testing your glow plugs would be first on my list. Takes about ten minutes with an ohm meter. Good plugs read about 0.7 ohms. Also, when was the last time a valve adjustment was done? What weight oil are you using? Do you/can you use the block heater? There's more after we know these answers.
sokoloff is offline
post #4 of 4 (permalink) Old 02-25-2008, 07:13 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Does the user name refer to Maui? I would assume a block heater would not be needed in that case
White smoke does not sound good, head gasket leaking? But would it make the car difficult to star? If not, then perhaps a fuel filter issue?
Diesel Benz is offline
    Tip-start ore touch start not working... totx W210 E-Class 0 12-17-2007 06:49 PM
    sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL-Class 7 01-02-2006 06:33 AM
    Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 06:51 PM
    Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
    Should my 1989 190e start in 2nd gear unless floor it from start? Guest (MBNZ) W201 190-Class 5 08-01-2002 12:27 PM
