My take on "lifetime transmission fluid" - Page 7 - Mercedes-Benz Forum
post #61 of 66 (permalink) Old 02-03-2014, 10:17 AM
ML3504matic's Avatar
Date registered: Jan 2011
Vehicle: 2009 ML 350 4Matic, 2000 CLK 430
Quoted: 6 Post(s)
My independent shop used Pentosin ATF1 for my CLk 430.
This has been used by some other members on these web sites, with great report-outs. My car's been driving great since as well.
It's not "on the list," but Pentosin says it meets specs and I believe there are many shops out there that do use this. For all those people who service their car at a shop and don't ask questions...who knows what's put in those. Pentosin replied to an email I sent and they do recommend their fluid for this tranny.
I've been keeping up on some of this discussion and seems like it just goes 360.
I'd recommend just getting what ever is on "the list" for peace of mind (if you're doing it yourself) and I do think Fuchs makes the OEM.
I have no complaints about the Pentosin, but if I made the choice for mine, I would have asked for Fuchs Titan.
ML3504matic is offline
post #62 of 66 (permalink) Old 02-03-2014, 11:31 AM
Date registered: Sep 2013
Vehicle: 2002 C320, 2006 R350 4Matic
Well I had to check the specs because I never heard of their ATF before.
http://pentosin.net/pressreleases/CR...in_ATF1_V3.pdf
The specs are probably close enough but it's Kinematic viscosity specs are a little thicker when it gets warm or hot. All the 236.14 fluids have a 6.Xmm^2/s range for 100C kinematic. the 40C Kinematic spec is higher too, so yea it is similar to the original 722.6 fluid viscosity at 7.6mm^2/s. It's also thicker when cold if you look at the -40C dynamic viscosity. They also measured the density at 5C higher than the fuchs spec sheet, but it is pretty close.
However it is "Fully Synthetic" (might not mean 100% synthetic in some cases especially American brand) and it might not degrade as fast. The motul 100% synthetic has a lower cold pour than Fuchs though, this fluid is the same at -51C. I see it on ebay for a 5liter Jug it's $62 shipped, so yea it's probably good enough and I wouldn't worry.
Heres the specsheet on Fuchs for comparison. Most 236.14 approved fluids don't deviate too far from these numbers.
http://www.generaloils.net/PI_TITANATF-4134_e.pdf
Actually thanks a lot for showing me this, I may be using it in the 722.6 next time instead of amsoil, both are not on the list, both are closer to the original fully synthetic fluid both being synthetic and in the 7.X Kinematic Visc Range. But I'd rather use the German stuff.
Fix'n Ma&Pa's Cars is offline
post #63 of 66 (permalink) Old 02-03-2014, 01:08 PM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
I checked Fuch ATF. Accoridng to Fuch site,
Fuch-3353 is 236.12 approved
and Fuch-4134 is 236.14 approved.
Then I checked the price from a Canadian online store, Fuch-3353 is actually more expensive. Fuch-3353 (4L) is $105 and Fuch-4134 (4L) is $55.
Since 236.14 is backward compatibale, it looks like Fuch-4134 is more suitable for our 722.6 transmission.
Also, I am only doing the pan flush, will this Fuch-4134 mix well with MB 236.14 ATF?
mis3 is offline
post #64 of 66 (permalink) Old 02-03-2014, 01:43 PM
Yea there was a Mercedes TSB around 2008 I think that says to use 236.14 for both 722.6 and 722.9(now that I think about it, this TSB is evidence they aren't sticking to lifetime fill anymore on 722.6 HAH). Except it says to use 236.12 for the Transfer Case on AWD 164 and 251 models.
I used Shell ATF 134 last time on the 722.6 and just did pan, filter, and electrical plug. I mixed the fluid and it was fine, Mercedes will say it's fine too if you ask them, as the dealers only do pan drop method, and many use Shell ATF which might be different from OEM fill, most if not all dealers will not drain the torque converter, I asked the SA already.
So yes, bottom line, mixing is fine, and 236.14 is fine in the 722.6 transmission. The fuchs might even be identical to your current MB fluid.
post #65 of 66 (permalink) Old 02-04-2014, 11:49 AM
Quoted: 5 Post(s)
I know many members here use Shell-134 but it is hard to get in Canada.
Now that I read about Fuch-4134. I like to find out more about this ATF. This ATF is about half the price of MB ATF and I can get it locally. Also, there is a chance that Fuch-4134 and MB ATF are identical.
First off, do any members have experience with this ATF?
mis3 is offline
post #66 of 66 (permalink) Old 02-04-2014, 06:22 PM Thread Starter
Kajtek1's Avatar
Quoted: 1223 Post(s)
Fuchs was recommended by my local indy warehouse as fluid used by local indys.
I bought a case of it for about $10/liter for future service on son's car.
I have high confidence with the advice and as I posted above, the Valvoline proved itself as well.
Kajtek1 is online now
    98 S420 Transmission "clunks" when coming to a stop alfaron W140 S-Class 1 05-13-2007 07:24 PM
    "lifetime sealed transmission" and your fluid change experience? one.bofh General Mercedes-Benz 12 01-20-2007 08:16 AM
    2003 E320 Transmission Question ( "C" or "S") setting jmorgis W211 E-Class 3 11-06-2003 01:05 PM
    To change the "life time" A/T fluid or not?? bgoin R170 SLK-Class 3 05-01-2003 04:21 PM
