Starting Problems 311 cdi - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-16-2008, 02:41 AM Thread Starter
Date registered: Feb 2008
Vehicle: Mercedes Sprinter 311 cdi XLWB
Hi All
newbie to site
Got a problem with Merc Sprinter 311 CDI (53 plate) due to cold weather not starting first thing in the morning. I have to bump start it every morning no lights coming on to say there is a problem. Once started it is all right for the rest of the day. Any ideas
ascouriers is offline
post #2 of 3 (permalink) Old 02-16-2008, 05:30 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Have you checked injector leaks? A friend of mine is unplugging the pressure sensor to increase rail pressure at start. Better to fix it if injectors are leaking.
Diesel Benz is offline
post #3 of 3 (permalink) Old 02-19-2008, 01:04 PM
Date registered: Jan 2008
Send a message via MSN to williamsdiesels.com
Most common is pressure regulator seals and injectors. Plenum chamber and injector cover off, disconnect multi plug and leak off pipe, clean out any diesel in top and crank over for 8 secs, no diesel and your injector is fine diesel and you have probs. Or you can call Williams Auto Diesels Ltd. We have das/star for all diagnostic needs and key coding/ start error faults etc.
We are mobile and travel all over the country as more and more people are unable to get their vehicles repaired within a reasonable time and cost.
williamsdiesels.com is offline
    ML CDI starting problems zak W164 M-Class 2 01-09-2008 02:12 PM
    E320 CDI (W210) starting problems,...Fuel shortage? CHEWIE W210 E-Class 1 12-12-2007 11:34 AM
    E320 CDI starting problems,Fuel shortage? CHEWIE W210 E-Class 7 12-11-2007 09:07 PM
    sprinter 311 cdi Chewy2k3 W901-905 Sprinter 0 04-18-2007 04:24 AM
    anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 10:57 PM
