EGR Valve...OE only? 94/e320 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-13-2008, 10:29 AM Thread Starter
Date registered: Feb 2008
Vehicle: 94/e320
Dear Experienced Ones,
I need a new EGR valve for my 94/e320. I don't know much about the part. Can I use a less-expensive after-market one (there's quite a difference in price) or will the cheap simply become expensive? Also, please, would cleaning the valve / system help buy some time?
Thanks
westing is offline
post #2 of 6 (permalink) Old 02-13-2008, 01:16 PM
Date registered: Jul 2004
Quoted: 340 Post(s)
I hate it when people answer my questions with a question - but nevertheless what is the evidence that you need a new EGR valve? Has it specifically been tested or are you just getting the EGR fault code? A failed EGR valve is far less common on your car than is a clogged EGR pipe.
deanyel is offline
post #3 of 6 (permalink) Old 02-13-2008, 02:51 PM Thread Starter
Vehicle: 94/e320
Hi deanyel. I didn't know you asked a question or I didn't know I answered it. Send me the link I'd love to read it. I looked a bit for the EGR answer before I asked but didn't find what I was looking for, maybe I didn't read enough. To answer your question, (my friend is the Benz expert, I'm a wannabe) we got a EGR fault code after the check engine light came on. I take it we should try cleaning the EGR pipe first? There I go again, another question. Thanks!
westing is offline
post #4 of 6 (permalink) Old 02-13-2008, 04:54 PM
Quoted: 340 Post(s)
Most likely a clogged pipe. Try a search - lots of info. The pipe snakes around from the EGR valve then behind the engine and to the intake side - hard to follow but possible. You need to disconnect both ends and runs a flex cable through it, something like a speedo cable. There is a redesigned pipe, less likely to clog, but installing it requires taking off the intake manifold, somewhat easier job just to clean out the old one.
deanyel is offline
post #5 of 6 (permalink) Old 02-13-2008, 07:02 PM Thread Starter
Vehicle: 94/e320
Great info. I'm EGR to try it. Sorry, bad joke. Thanks for your help!
westing is offline
post #6 of 6 (permalink) Old 02-13-2008, 07:43 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 751 Post(s)
OEM EGR valves are most definitely available for a substantial savings compared to your friendly neighborhood dealer.
GeeS is offline
removing egr tube from egr valve....benefit brandon671 W126 S,SE,SEC,SEL,SD,SDL Class 16 07-19-2012 05:38 PM
EGR valve srfox W210 E-Class 3 04-24-2007 09:06 AM
egr valve bobfromboss W210 E-Class 0 07-07-2006 01:43 AM
EGR valve. nobby R/C107 SL/SLC Class 6 02-15-2006 09:01 PM
EGR Valve Help! spsinha W124 E,CE,D,TD Class 0 11-17-2002 12:48 PM
