Part # A0004640318 'reed coil' 'spring coil' - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-31-2008, 08:35 AM Thread Starter
pokdub's Avatar
Date registered: Dec 2007
Vehicle: CL500, 2003, Command 2
I am hoping someone on the forum might be able to help me identify the above part number. It has been identified as the problem associated with an SRS warning light, and needs replacing.
Part is likely to be in the area of steering column, dont know location, dont know size, dont know function, dont know how easy to access.
Appreciate any info from parts expert.
Rgds
POKDUB - Ireland
2003 CL500
pokdub is offline
post #2 of 5 (permalink) Old 01-31-2008, 12:40 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Part #40 here:
http://www.detali.ru/cat/oem_mb2.asp...SGR=105&SGN=05
It is the part that takes care of airbag wires coping for the steering wheel rotation.
You would have to take the steering wheel off to change the part. Be careful with the airbag if you are doing it yourself.
Diesel Benz is online now
post #3 of 5 (permalink) Old 01-31-2008, 03:28 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
I think it is also called the "clock spring"
Peter Guenther is offline
post #4 of 5 (permalink) Old 02-01-2008, 07:10 AM Thread Starter
pokdub's Avatar
Many thanks for the site pointer. It locates and IDs the part perfect (40).
I will now look into getting access to the unit in question. I suspect the unit is fine but some contacts are loose and may need reseting/cleaning. (Funny, I had to make a horn contact collar like this for an older car).
The SRS light came on when the steering wheel was being moved, I am sure it is a contact issue.
Tks again.
POKDUB - Ireland
2003 CL500
pokdub is offline
post #5 of 5 (permalink) Old 02-02-2008, 06:42 PM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
either way you will still have the light on whether the issue gets fixed or not. srs codes have to be cleared once fixed.
Streetglower is offline
    spacer for coil spring nipon G-Class 1 12-16-2007 05:19 PM
    Part # for 13mm Coil Spring Shim for front mrBENZE W126 S,SE,SEC,SEL,SD,SDL Class 2 11-07-2007 10:39 AM
    FS Coil Spring Compressor KKM For Sale/Wanted/Trade/Giveaway 0 07-23-2007 04:27 PM
    front coil spring ewan69 V-Class 0 04-09-2007 05:32 AM
    broken coil spring tanex G-Class 7 10-12-2005 03:53 AM
