Engine judder - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-25-2008, 07:48 AM Thread Starter
Date registered: Jan 2008
Vehicle: E320 Avantgarde (1998) saloon
Engine judder
Wander if anyone can help, I have a 1998 E320 saloon (auto) with 78,000 miles and a full history. It has developed a rather annoying problem when under hard acceleration (overtaking etc).
When you accelerate hard the revs build nicely to 4000/4500 rpm when all of a sudden the car begins to judder like a bugger and it won't accelerate through the problem (or past 4500rpm) if you keep the accelerator pedal down. It feels almost as if the engine is being starved of something i.e. fuel/air.
Strangely though if you hold it in 1st, 2nd, 3rd etc and accelerate gently it will go past 4000/4500 rpm with no problem
I would be most grateful if anyone could give me some advice on this one.
jeff1418 is offline
post #2 of 5 (permalink) Old 01-25-2008, 08:08 AM
eric242340's Avatar
Quoted: 300 Post(s)
When you accelerate hard the revs uild nicely to 4000/4500 rpm when all of a sudden the car begins to judder like a bugger and it won't accelerate through the problem if you keep the pedal down.
You have to start somewhere and I would advice four wheel balance as it sounds like you have a bent wheel. From what you have posted it will most probably be a rear wheel.
ERIC.
eric242340 is offline
post #3 of 5 (permalink) Old 01-25-2008, 09:42 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
I'd have the cats checked. If they've collapsed internally, the symptoms would be as you've described.
MarcusF is offline
post #4 of 5 (permalink) Old 01-27-2008, 07:09 AM
Jonathan Wallin's Avatar
Date registered: Oct 2006
Vehicle: S600 C140 1994
First change fuel filter, air filter and spark plugs if thats not done allready.
An easy way to start.
~C140 S600~
http://www.garaget.org/?car=34361[/url]
Jonathan Wallin is offline
post #5 of 5 (permalink) Old 01-27-2008, 04:30 PM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 241 Post(s)
+1 on the fuel filter
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
    Side Windows judder malcolmam R129 SL-Class 0 10-23-2007 10:17 AM
    Judder whilst accelerating bielefeld280se W124 E,CE,D,TD Class 2 09-24-2006 07:38 PM
    ABS PEDAL JUDDER SORTED BEFORE M.O.T. perday W201 190-Class 8 03-16-2006 07:28 PM
    Brake judder muttley W201 190-Class 3 02-26-2006 08:20 AM
    Clutch judder when cold petermerle G-Class 1 02-09-2004 03:14 AM
