1989 300 te falls on it's face when it rains - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-20-2008, 09:08 AM Thread Starter
Date registered: Feb 2007
Unhappy 1989 300 te falls on it's face when it rains
i have been trying to figure out a problem with this car for a year now. The car has no throttle response, and will barely idle at the slightest sign of moisture in the air. I have checked the cap for cracks, replaced the wires, because the coil wire looked like it was burnt from arcing on the power steering resorvoir [where the previous owner had it tightly wire tied to], the coil had been replaced shortly before I bought the car. The guy thought the coil was the problem and told me it ran rough after it rained but the coil took care of it. WRONG. Yesterday I took the throttle position sensor off to see if I could clean the connections, a mechanic at an independent Mbz shop told me to do this. When I got the sensor off I found no connections, it was a plastic piece that attached to the throttle plate. No electronic connection to get condensation in it. The next I found was a bare wire at the sensor on the end of the cylinder head, it is the green sensor with the 2 seperate connectors on it. My question is could this wire being bare effect the running of the car when it rains. I have kept the car in the garage when it has rained and it still happens. It is very sensitive to the moisture. Any advice on this problem would be much appreciated. Thank you
edwinb is offline
    1989 300 SEL in NJ JThw8 For Sale/Wanted/Trade/Giveaway 1 07-09-2007 09:40 AM
    1989 300 te barely runs when it rains? edwinb General Mercedes-Benz 5 02-22-2007 05:22 PM
    1989 300 ce who_am_i W124 E,CE,D,TD Class 3 09-22-2004 12:12 AM
    Alternator for 1989 300 CE edcole58 General Mercedes-Benz 1 06-08-2004 06:18 AM
    1989 300 e grill Costaricabenz W123 E,CE,D,CD,TD,TE Class 5 11-11-2003 03:18 AM
