air flow mass-valve - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-18-2008, 01:01 PM Thread Starter
Date registered: Dec 2007
air flow mass-valve
hi i have a c200 compressor 2001 model.i have changed recently the air flow mass meter.the other day engine warning was on again!! my mechanic told me that there is kind of valve that is behind the air flow meter and there is a need to change it.the fault code was (AMF short possitive).exactly he told me that everybody changes that valve with the air flow meter as pair otherwise you will have that true or i have to change my mechanic?has someone the same experience?thanks
mariosg76 is offline
post #2 of 3 (permalink) Old 01-26-2008, 09:47 AM Thread Starter
my mechanic was right!when ichanged that air valve everything was ok
post #3 of 3 (permalink) Old 01-26-2008, 11:04 AM
Kajtek1's Avatar
Quoted: 1068 Post(s)
He might be right that your valve was bad, but he is dead wrong that this is consumable item like MAF. Those throttle valves usually last longer, than the car.
How much was it?
Kajtek1 is online now
    Air Mass Flow rajrahman C208/A208 CLK-Class 15 10-12-2012 08:38 AM
    Mass Air Flow meter Jrousseau W124 E,CE,D,TD Class 0 11-12-2006 01:27 PM
    Mass Air Flow Sensor DanStubbs C208/A208 CLK-Class 8 10-14-2005 03:28 PM
    Mass Air Flow Sensor? jenjenstar W202 C-Class 5 07-21-2005 08:42 AM
    Dirty air filter/bad mass air flow sensor 4benzes W163 M-Class 1 01-05-2005 04:49 AM
