Driver's Side Seat Belts LOCKED - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-13-2008, 08:38 PM Thread Starter
Date registered: Jan 2008
Vehicle: e55 AMG
Hi everyone,
I purchased my e55 at an insurance auction. The driver's side suspension had the Spindel / Steering Knuckle damaged. It seems like the driver hit a curb. The Spindel was damaged but the body is flawless (no damage on the fender, etc.).
The problem is that the Driver's Side Seat Belts seem to have locked because of the minor accident. The Seat Belts do not reach the Center Push Buckle. I removed the side panel on the driver's side to see if I could fix the problem but when I got to the pulley it would not budge and would not allow the rest of the seat belt to be pulled out. Is this due to a sensor gone bad? Is there a way to unlock the pulley and allow the seat belt to work? Is this common on mercedes that have been in any type of accident (even minor) ?
Lastly, does anyone know how to remove the REAR passenger seat?
Thanks in advance
uluna is offline
post #2 of 2 (permalink) Old 01-16-2008, 05:42 AM
mr.dirt's Avatar
Date registered: Feb 2007
OK It sounds like the seat belt retractor system engaged during the accident. The slack in the seat belt is taken up by an actuator using a similar charge to the airbag. The actuator needs to be replaced. OEM parts only.
The rear seat should have a red lever under the front corner near the door (1 each side). Pulling this forward will release the seat bottom.
mr.dirt is offline
    URGENT: Seat Belts Locked... Cloak559 W124 E,CE,D,TD Class 4 01-20-2008 12:24 PM
    Driver's Side Seat Belt LOCKED uluna W211 E55 AMG, E63 AMG 0 01-13-2008 10:16 AM
    99 E320 DRIVER'S SIDE Seat Adjustment/Window...LOCKED? gemee W210 E-Class 11 12-03-2006 08:31 PM
    driver's seat moves side-to-side --> normal??? loveofdriving W203 C-Class 3 06-19-2005 08:54 PM
    Anyone know where I can get colored seat belts? Like the custom porsche belts? Long R170 SLK-Class 1 04-29-2001 03:24 PM
