looking for a RUG in diesel tank post - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-12-2008, 04:48 PM Thread Starter
Date registered: Jan 2008
and cant find any. looking for any previous work done when regular gas is run on diesel engine . ty
knarfy is offline
post #2 of 5 (permalink) Old 01-13-2008, 12:17 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
You mean gasoline accidentally filled on a diesel? Did you drive, how much.
http://www.benzworld.org/forums/w211...el-engine.html
Diesel Benz is offline
post #3 of 5 (permalink) Old 01-13-2008, 06:10 PM Thread Starter
about 7 gallons while on reserve. its a mistake by the new gas station attendant. after i towed the car back to the shop told him what the repairs may be, about 3 to 6 hrs of labor plus parts..well the old man just about passed out. needless to say he didnt show to work today and... dont think he will ever..lol. will have to take a closer look tomorrow. btw its a 87 300 sdl turbo. for what i can see the tank is behind the rear seat? there is a line that runs adjacent to the break lines to a clear filter before the injection pumps..? im gonna drain the tank and try to air preasurise it to blow all the fuel out and same up to the pump. replace filter and maybe loosen lines to cylinders to drain excess fuel..? refill and use additives to clean up . any ideas? thanks.
knarfy is offline
post #4 of 5 (permalink) Old 01-13-2008, 10:01 PM
Quoted: 39 Post(s)
You say you towed it back, do you mean you did not drive, not even start the car after the incident?
If you did not drive, it might be enough to just drain the tank and fill it with diesel. But the fuel filter change and fuel line drain would make it even better. After all, this engine would accept some gas mixed with diesel.
post #5 of 5 (permalink) Old 01-14-2008, 06:08 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
7 gallons on reserve would make it 1:1, what is too much. As mentioned some gas in diesel is not harmful and old remedy for cold weather was adding a gallon, or 2 for tank to avoid gelling.
I am pretty confident that filling it up with diesel and driving would not do any damage, but to be on safe side it is definitely better to drain the tank and lanes before restarting. You have fuel lanes on the firewall, so with MityVac you could simply suck it out.
But. Don't exaggerate it. You really don't need to open the tank and sponge it.
Kajtek1 is offline
    I need help!!!! Wet Rug happyboy W202 C-Class 8 07-22-2007 06:54 PM
    Gas/diesel tank sealer kimmer Unimog 6 04-02-2007 08:03 PM
    Diesel tank line WeVonBraun W123 E,CE,D,CD,TD,TE Class 4 07-10-2006 04:38 AM
    Diesel tank venting Crashmaster Unimog 4 07-04-2005 08:40 PM
    diesel tank capacities dipple G-Class 4 04-18-2003 01:32 PM
