Limp Home Mode - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-06-2008, 06:16 AM Thread Starter
Date registered: Jan 2008
Cool Limp Home Mode
Car: Merc. C 220 elegance 1994 petrol Auto UK model
Problem : Limp Home Mode
Turn ignition key = engine starts = idle climbs up to 1000 RPM then goes
into L.H.M. = switch of ignition = restart and the same thing happens.
the car used to travel approx. 15 miles before it went into L.H.M but by quickly turning the ignition
On/Off while driving you would get another 2 miles or so, I then lost interest and put the car on hold for a year
and bought a 1995 E200 petrol estate this had to have a head gasket replaced and now has a problem which is:
when cold and first started it drives fine but after a few minutes of running the idle becomes lumpy intermittidley
and feels like its firing on 3 until it picks up speed then its ok , meaning it drives fine on motorways etc until you stop at a junction and need to drive off again also I'm sure I can sometimes hear faint backfires when driving off from a standstill.
could it be the coils for the spark plugs breaking down and causing the excess fuel to explode.the fuel consumtion appears to have increaced.
thanks
Brian
bbrreid is offline
post #2 of 2 (permalink) Old 01-17-2008, 05:58 PM
Date registered: Nov 2007
Vehicle: CLK320 sport
Limp mode
I had simlar problems with my CLK320. Replaced mass air flow meter & brake pedal switch after having diagnostics done by independant but the problem still persisted. In the end I bit the bullet & took it to MB main dealer. Best thing I ever did, they cleared all the stored fault alarms & found that the throttle body was faulty, car has been fine since this was replaced. Hope this helps.
CLK320rob is offline
    s600 limp home mode getonit W140 S-Class 13 10-06-2010 01:57 PM
    CLK Limp Home Mode!!! Median C209/A209 CLK-Class 5 10-19-2007 03:20 AM
    Limp home mode? rlbmd2006 W203 C-Class 0 08-27-2007 10:27 AM
    Safe Mode/ Limp Home bendont V-Class 10 04-27-2007 07:16 AM
    Limp home mode billreddrop W210 E-Class 0 11-23-2006 09:17 AM
