car hydrolocked help!!! - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-05-2008, 07:04 PM Thread Starter
Date registered: Jan 2007
so i drove over like 4-5 inches of rain and my car hydro locked and the dealer saids that i need to replace the motor and the warranty doesn't covers it. What should i do the car only have about 10000 miles on it and is it really necessary to replace the whole motor? Please help
Wanted is offline
post #2 of 7 (permalink) Old 01-05-2008, 07:28 PM
Mike Tee's Avatar
Date registered: Aug 2007
Vehicle: see signature
Quoted: 65 Post(s)
Send a message via Yahoo to Mike Tee
Water doesn't compress, so you've almost certainly destroyed the engine - the connecting rods may be bent. How fast were you going to be able to ingest that water into the air intake????
2008 Mercedes-Benz B 200 5 speed
2006 smart BRABUS Tailor Made Canada 1 cdi cabriolet
2013 Ford Fiesta SE 5 speed, for the kids
1966 Peugeot 404 Coupé Injection, restoration underway
Mike Tee is offline
post #3 of 7 (permalink) Old 01-05-2008, 09:46 PM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
mike tee is right, if you bent a rod or spun a bearing you have problems. Either way you will have to rebuild the motor, as far as replacing it i don't think so. Good luck!!!
livefreeordie is offline
post #4 of 7 (permalink) Old 01-05-2008, 09:57 PM
joshuajeeper's Avatar
Date registered: Sep 2006
Vehicle: 1985 Mercedes 300TD, 2014 GLK250 Bluetec
Considering that your car only has 10,000 miles on it, it wouldn't have a M119 or M104 motor or older therefore, yes, with a bent rod, the engine block would also be damaged. The block is unmachineable. (Including all motors after the M104/119).
1985 300TD - "Panzer Wagen" - undergoing full restoration (resto - mod)
2014 GLK250 Bluetec (Wife's Car)
Mercedes-Benz Master Certified Technician.
http://www.flickr.com/photos/joshuajeeper/
joshuajeeper is offline
post #5 of 7 (permalink) Old 01-06-2008, 06:51 AM
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
most people go through insurance when this happens. you might as well too as a new engine is around 10-15K and up, not including labor to install.
Streetglower is offline
post #6 of 7 (permalink) Old 01-06-2008, 08:35 AM
chromejunkie's Avatar
Date registered: Dec 2007
Vehicle: bike cost too much to drive
you can have the heads pulled off and the pan then go from there .
living on the edge driving a fine line
chromejunkie is offline
post #7 of 7 (permalink) Old 01-06-2008, 09:37 AM
Kajtek1's Avatar
Quoted: 1248 Post(s)
Hydro-lock at low speed doesn't have to mean engine damage. Even if a rod is slightly bend, it can be replaced.
I would start with pulling the plugs, making sure there is only oil in the pan and trying to turn the engine. With some luck (actually lot of them) the water will blow off and the engine will fire up. I did lot of water drainage from my PWC engine, but that is 2-stroke.
Kajtek1 is online now
