w210 (98) harmonic balance pully. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-04-2008, 03:49 AM Thread Starter
Date registered: Jan 2008
Vehicle: 98 E240 silver
Red face w210 (98) harmonic balance pully.
my pully lost its membrane rubber, and i drove the car home, by looking up the forums i think i might have done a bit more damage than just replace the pully????? can anybody help and give advice on how to change same wj.
P.s.have i any claim against mercedes as i have read this was a call back item by m,b. but when ordering parts in m,b. main dealer in ireland they have never procesed any claims?
wj. is offline
post #2 of 4 (permalink) Old 01-04-2008, 04:21 PM
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 1998 E320 Wagon
Quoted: 26 Post(s)
Check out 'Sticky' Post number 3 above.
RichardM98 is offline
post #3 of 4 (permalink) Old 01-04-2008, 05:03 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, wj and welcome to the forum. Please take a moment to update your BW profile re: vehicle and location, that info can be really useful.
Driving the car with a failing HB can have some negative results, typically they are peripheral (belts, accessories, radiators, fans, etc.).
There was a recall (Richard has pointed you to the sticky) but I'm not sure whether it applies outside the US. If it does you would be covered for the repair except to the extent the dealer determines that you caused additional damage (I won't tell you what to say except that if it all happened at speed and it looked like that by the time you were finally able to pull over.... ).
In any event, call the local dealer and give them your VIN, they will tell you if there is a valid recall program on the Green Isle for your car. I'm crossing my fingers for you!
Take care and enjoy the ride,
Check Codes is offline
post #4 of 4 (permalink) Old 01-04-2008, 06:10 PM Thread Starter
thanks GREGG/RICHARD i am wating on the parts to arrive,have not stripped it down so i do not know how much damage i have done to the sump and chain cover, i,m hopeing a metal repair new seal/pully/belt and happy days????? what annoys me most i got no warning noise ect and was not aware this problem existed.
best regards wj, dublin.
wj. is offline
    Crank Pully / Harmonic Balancer Recommendation Needed. dn54168 W210 E-Class 4 12-06-2007 04:20 AM
    ******** pully? brabus550cls C219 CLS-Class 1 06-25-2007 03:38 PM
    Carlsson Pully kit or Kleemann pully kit? MoNd3sTo7 W203 C-Class 1 12-30-2005 08:12 PM
    Carlsson pully kit or Kleemann pully kit? MoNd3sTo7 W210 E-Class 4 11-29-2005 09:04 PM
    HARMONIC BALANCE PULLEY ADVISORY Jason903 W220 S-Class 2 04-22-2005 05:06 PM
