500sl - 16" rims to 18" - rough ride? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-03-2008, 04:52 PM Thread Starter
imosh's Avatar
Date registered: Jan 2008
Vehicle: 1992 500sl
Question 500sl - 16" rims to 18" - rough ride?
i figure it will be slightly worse, will it be?
'92 sl
imosh is offline
post #2 of 3 (permalink) Old 01-04-2008, 10:18 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Of course.
To maintain the proper rolling diameter, sidewalls must be shorter.
In addition to rough ride, you'll have increased susceptibility to wheel and tire damage and your tires will flatspot more readily when the car is parked for a few days.
It's 100% form over function unless you're planning on racing and if your racing's on the street it's still form over function.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 01-04-2008, 02:44 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
'92 sl
Hi, imosh, welcome to the forum. Please take a moment to complete your BW online profile re: vehicle(s) and location, that information can prove to be quite helpful.
The stock tire size on your car was 225/55/16, the nominal equivalent in 18 is 245/40. A 40 profile tire will definitely increase the harshness you feel in your ride, so it may depend on (1) how good the roads are around you and (2) how much you care. You will pick up a bit of handling (more tread on the road, faster response through a shorter sidewall) but as lkchris notes, usually this is more about looks than anything else. Personally I found going to 17s was a great compromise, the ride quality barely changed and the look is a bit better (for yours that would be 245/45/17). In my experience 45-50 series is pretty much the "breaking point" for comfort, anything below that it's simply too harsh but again that is to some degree a matter of personal comfort.
Last thought, as you narrow the sidewall you also increase the odds of damaging a wheel due to road damage or debris.
Take care and enjoy the ride,
Check Codes is offline
    FS R129 500SL "F1" Formula One edition fender badges Vin-barrett For Sale/Wanted/Trade/Giveaway 4 11-10-2007 03:58 AM
    ride quality w/ 22" rims 06ml500 W164 M-Class 5 05-22-2007 02:22 PM
    WILL 20" RIMS DESTROY SMOOTH RIDE SIFU1010 R230 SL-Class 15 06-06-2004 09:57 AM
    how rough is the ride with 19" wheel/tires???? QuadCam The Discount Tire Direct Tire, Wheel, Brake & Suspension 6 06-26-2003 11:10 PM
