Power Steering Reservoir - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-03-2008, 07:47 AM Thread Starter
Date registered: Jan 2008
I have a 1999 ML320. A couple days ago i noticed a spot in my drive way and the last couple of days i have this shieking noise when i start my truck up that i have never had and when i turn the wheel notice it gets louder and my steering will pulls a little but when i am driving staight evey thing is ok... A friend of mines thinks i am low on power steering fluid or my have a leak. My question is where is the power steering reservoir on a 1999 ML320 for me to check it... and if it is low... can i use just any power steering fluid or does it have to be MB? Help please.
bowenss is offline
post #2 of 8 (permalink) Old 01-03-2008, 08:17 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
I would put MB fluid, it doesn't take a lot of it anyway.
The reservoir would be on top of the pump. If you follow the poly-V belt to the find the pump, you will find the reservoir. The cap would have a level stick.
Diesel Benz is offline
post #3 of 8 (permalink) Old 01-03-2008, 09:43 AM Thread Starter
Thanks for the info... don't mean to be a nit wit but I am a female and have no clue about that ploy-v belt your talking about... let me tell you what i think it is and you can confirm(hopefully)... There is a cap just under the engie cover on the driver side towards the front of the truck... i had to left the engine cover up just a little bit to be able to slide the cap off... when i pulled the cap off there is a little stick that is about 1/2 inch long that stick from under the cap. Am I in the right spot?
bowenss is offline
post #4 of 8 (permalink) Old 01-03-2008, 10:10 AM
Quoted: 35 Post(s)
This time the parts diagram isn't showing the location too well and I did not find a figure for the 163.154 but this attached photo should be from a W220 and should be pretty similar to your ML. I believe it confirms that you did find the correct cap and oil reservoir.
By the way, there may be an issue with the oil power steering hose, leaking at the front of the car, close to the radiator. I don't want to put the document here, if interested, PM an email address and I'll send the document.
post #5 of 8 (permalink) Old 01-03-2008, 10:14 AM
Quoted: 35 Post(s)
By the way, MB approved steering gear oil types for the ML should be:
Fuchs Titan PSF,
MB 236.3 steering gear oil, or
Mobil ATF D.
post #6 of 8 (permalink) Old 01-03-2008, 11:21 AM Thread Starter
Thanks this looks just like the cap i found...
bowenss is offline
post #7 of 8 (permalink) Old 01-03-2008, 01:29 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
I think that you should also investigate that leak....
keyhole is online now
post #8 of 8 (permalink) Old 01-03-2008, 04:12 PM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
Does this look like yours ML?
Hope this helps
ID:	155922   Click image for larger version
Name:	ml 320 2.gif
bmeister is offline
    Power steering reservoir O-ring Jexpert W163 M-Class 24 12-13-2013 05:26 PM
    ml-320 power steering fluid reservoir saltof W163 M-Class 5 12-18-2007 08:43 AM
    What is this doohicky in my power steering reservoir? ChuangTzu W123 E,CE,D,CD,TD,TE Class 9 03-04-2007 09:45 PM
    power steering pump reservoir perdidojoe W163 M-Class 2 02-05-2007 05:02 PM
    Power steering reservoir tobyd W124 E,CE,D,TD Class 4 01-31-2006 11:17 AM
