'05 C230 Oil change... - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-01-2008, 02:15 PM Thread Starter
Date registered: Jan 2008
Post '05 C230 Oil change...
I need to get my oil changed and live far enough away from the nearest Mercedes service location that it would be beneficial to find someone local to do it. My local oil/lube shop states they will allow me to utilize them for the change provided I tell them how. I have all the filters (OEM) and know how to check the level, the only thing is....where do you add the oil? Is it introduced into the system from where the oil filter is removed? Also, would you chose Mobil 1 synthetic over conventional? Thanks for any constructive input.
RockChalkC230 is offline
post #2 of 5 (permalink) Old 01-01-2008, 03:34 PM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 90 Post(s)
Naturally use Mobil 1 full synthetic all the time. I'll go looking for the oil fill and get back or maybe someone out there with an 05 C230 will help!! Your saying that there's no visible oil fill cap. Strange!
DEVOURS is offline
post #3 of 5 (permalink) Old 01-01-2008, 05:40 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
I would never, EVER, utilize the services of a shop that told me they’ll do the work if I tell them how. If they don’t know how to perform an oil change, paying them to learn on my vehicle would be out of the question.
Your C230 has an oil filler cap. That is where oil is added. If you have a C230 Kompressor engine, I think it looks like the one in the attached photo. If so, the arrow points to the oil filler cap.
MarcusF is offline
post #4 of 5 (permalink) Old 01-01-2008, 06:05 PM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
i was thinking the exact same thing. i am also thinking what kind of oil shop doesnt know where to and how to change/add oil. what kind of retards work there if they are there to CHANGE OIL.
Streetglower is offline
post #5 of 5 (permalink) Old 01-01-2008, 07:55 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
There is a DIY oil change post in the W203 forum (the specific one for your car).
That said, why not just do it yourself? Buy the vac device, it's all done from above and why give money to other people to learn how to do their job?
Mobil1 0W40 is the proper spec oil for your car. Once you've gotten the old oil out, pour the new in right where the filter assembly goes. Bigger hole, less likely to spill.
And if it's not clear, I'm in full agreement with the other posts: go somewhere else if you're not willing/able to do it yourself. No way those guys can be trusted.
Take care and enjoy the ride,
Greg
Check Codes is offline
    How to DIY oil change on your C230 spoons W203 C-Class 132 09-15-2016 05:06 PM
    1998 C230 Transmission Oil Change ojrana W202 C-Class 6 09-01-2008 07:58 PM
    How to change oil on 2006 C230 hungndao BenzWorld Help 1 10-16-2007 06:42 PM
    98 c230 oil change...need help bscmotor W202 C-Class 2 08-12-2007 12:10 AM
    Any tips for: DIY Oil Change: 98 C230 Kompressor sunnfyfx W202 C-Class 3 02-20-2007 11:20 PM
