ML 320 Power Steering Failure - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-01-2008, 09:59 AM Thread Starter
Date registered: Jan 2008
Vehicle: 1999 ML 320 130k Miles
Smile ML 320 Power Steering Failure
Hi All,
I have a '99 ML 320 with a power steering issue. I had what can only be desribed as a catastrophic failure of the P/S system. One minute fine then with a whine the system went down and I could hardly steer. Looked under the hood and although the fluid was leaking it was hard to locate the source as it was dark. Anyone have a thought ? Am I looking at a new pump or a couple of hoses and clips ?
Thanks for looking.
JF
jomiji47 is offline
post #2 of 5 (permalink) Old 01-01-2008, 06:18 PM
You are going to have to replace the hose that goes from the P/S cooler to the rack and pinion. There has been several DTB's and/or recalls. If you take it to the dealer they will know exactly what you are talking about. If you keep running the pump dry you will need a new pump but a new line should be fine. Get that sucker fixed ASAP .
CaliCoast is offline
post #3 of 5 (permalink) Old 01-01-2008, 07:58 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Sounds like a blown hose, but you may also need a new pump depending on how far you drove it after it failed. Hopefully you didn't? But if you did then go ahead and drive it to the mechanic and bring both checkbooks. Otherwise have it towed in.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #4 of 5 (permalink) Old 01-01-2008, 09:00 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
Yeah, the pumps are pretty popular, we get a lot of calls on 'em.
GeeS is offline
post #5 of 5 (permalink) Old 01-02-2008, 02:49 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
first you need to find out where its leaking from. although the lower hose is common, it could be the seal on the resovoir, could be the pump, anything
Streetglower is offline
    Power Steering Failure dmico2 W163 M-Class 8 07-28-2007 06:32 PM
    Power Steering Failure... orlandotrader W163 M-Class 4 10-19-2005 10:36 AM
    Power Steering Failure knudsenr W163 M-Class 1 01-24-2005 08:35 AM
    Power Steering Belt Failure? Indy Joe R170 SLK-Class 1 05-01-2002 02:57 PM
    OT: E 320 power failure? Chris(LE) R170 SLK-Class 2 08-30-2001 05:44 AM
