4 Matic Failure Light - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-28-2007, 08:38 AM Thread Starter
Date registered: Dec 2007
Vehicle: 1992 M-Benz 300E 4 matic
Send a message via AIM to MichaelR Send a message via Yahoo to MichaelR
My 1992 300E 4 Matic Light has come on and remailns on (not the "triangle light). Some say disconnect the neg from the battery and it will reset the system. Should I disengage the system via the lever under the hood first?
I only have 75K miles on this beauty, I hope it is a simple (and inexspensive) solution!
MichaelR is offline
post #2 of 2 (permalink) Old 12-28-2007, 02:07 PM
Kajtek1's Avatar
Quoted: 1166 Post(s)
Disconnecting the battery will reset monitoring system, but not the faulty mechanical parts.
I researched the older 4-Matic version and it has extremely bad reliability records. That made me spending more money on the newer one.
From what I remember the light means that the front axle don't engage anymore, leaving the car in RWD mode permanently. Lot of owners drive like that not wanting to spend big $$$ to repair faulty transfer case.
Good luck.
Kajtek1 is online now
    4 Matic warning light Bob S W124 E,CE,D,TD Class 2 05-02-2005 07:32 AM
    Rear Running Light /parking light Failure Raheel R129 SL-Class 1 09-05-2004 04:21 PM
    service light is on 98e320 4 matic skislope96 W210 E-Class 2 04-15-2004 10:01 AM
    4-matic light stays on! Help. bkv W124 E,CE,D,TD Class 0 12-10-2002 02:37 PM
    My 300 TE 4-matic...grinding noise from front & 4-matic light on in dash display? Guest (MBNZ) W124 E,CE,D,TD Class 0 12-06-2001 06:32 AM
