EPC (Severe) error - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-28-2007, 06:28 AM Thread Starter
Date registered: Nov 2006
EPC (Severe) error
Hi ,
I've had the EPC program for quite a while, although I uninstalled it to clean up the pc,
Now when i try to re-Install it i get a pop up box with "Severe", has anyone found how to get round ths or what is causing it.
I found this part in the instructions
You MUST un-install all other EPC's first. Otherwise when starting the
install program, you will get a 'Severe' error stating 'Incompatible
Program Found'. Run the uninstall program from your old EPC. If it is not
listed in 'Add/Remove Programs', you may need to search for a program
named 'BHUNINST.EXE' on your old EPC install disc
But i cant seem to find the uninstall program, has anyone else has this problem.
smiddyboy1 is offline
    Severe thunderstorms in Eastern NC Designo_E320 Off-Topic 38 08-13-2007 11:07 PM
    Severe Engine Shake panamacolin W123 E,CE,D,CD,TD,TE Class 4 06-17-2006 04:26 PM
    Error installing PM (Program Manager) for EPC - WIS shineonyou Audio & Telematics Forum 13 12-27-2005 08:40 AM
    EPC Part # Help. My EPC not correct. Need ASAP Alex Guess G-Class 4 09-30-2004 06:57 AM
    Severe SLK withdrawls Brian_R170 R170 SLK-Class 9 01-03-2003 06:17 AM
