**Help Please** c-class C32 AMG TV Tuner - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-27-2007, 05:41 AM Thread Starter
Date registered: Dec 2007
Can anybody help. My tv tuner on my c-class (c32 amg) has stopped working ang gives a No Tv error on the screen after further investigation found out that no Live power was going in. So we wired a direct live. Now the TV tuner works but there is no signal. Does any body know which fuse is for the TV tuner? Also is there seperate power source for thhe aerial? If so where is the ariel? And finally Is there a seperate fuse for the aerial ( I am assuming that there is some sort of booster)?
albara is offline
post #2 of 3 (permalink) Old 12-27-2007, 08:57 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
You should find the fuse box locations from the car manual. Each fuse box should have a sticker indicating the fuse assignment.
The TV antenna(s) should be at the rear window, an amplifier unit is located to the top of the rear window, and on the left.
The rear SAM provides power to the TV tuner.
On a sedan I believe the TV antenna amplifiers are powered from the TV tuner without a separate wire from the signal coax. No separate fuse for the TV aerial amp.
I would have investigated on the cause of no power to the TV unit before wiring it elsewhere. Did you connect a switched or permanent power line to it?
Diesel Benz is offline
post #3 of 3 (permalink) Old 12-27-2007, 01:33 PM Thread Starter
I connected a permanent power line to it. I've also checked all the fuses and they seem ok.
albara is offline
    TV Tuner on E Class (W211) stranger Audio & Telematics Forum 6 02-29-2008 01:19 AM
    anyone need body kit such as: Amg C43,Lorinser,Carlson for mercy C-class,A class,E class,S class,Clk Guest (MBNZ) W202 C36 AMG, C43 AMG 16 04-01-2007 03:28 PM
    Mercedes E class w211 2004 TV tuner for sale rajasehgal Audio & Telematics Forum 1 09-20-2006 05:26 AM
    Needing help in TV Tuner Installation in a MB E-class Gvidix W210 E-Class 2 08-24-2006 02:45 AM
    Needing Help in tv tuner installation in merc e-class W211 Gvidix Audio & Telematics Forum 0 08-22-2006 09:33 AM
