Smell of raw fuel - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-26-2007, 12:01 PM Thread Starter
Date registered: Dec 2007
Smell of raw fuel
I have a 1989 300E and have noticed the odor of gasoline when I use the heater. Presumably drawing in the odor from the engine compartment, though I cannot find any signs of leaking fuel. Any ideas?
Thanks.
dmpohly is offline
post #2 of 3 (permalink) Old 12-26-2007, 05:01 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
If you have a charcoal cannister/vapor recovery system, those will reek of gas when they fail (and they can fail a number of ways).
MarcusF is offline
post #3 of 3 (permalink) Old 12-26-2007, 06:42 PM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 242 Post(s)
Thanks.
If you are a DIY type person take off the air cleaner and check the fuel enrichment valve. it is on the rear side of the fuel injection distributor. Its black, held on by two screws and is 1 inch by 1 inch by two inches. These things develop a leak and since the proximity is relatively near the heater blower it makes sense you are smelling it when the climate control is running. they are simple to change but cost approx $300 from the dealer.
Good luck.
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
    fuel smell John Mars W163 M-Class 2 08-10-2007 08:42 PM
    Fuel Smell Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 7 07-05-2007 07:51 PM
    Raw diesel exhaust smell peww 240DieselPower W123 E,CE,D,CD,TD,TE Class 1 05-05-2007 07:25 PM
    Raw gas smell rsmith R/C107 SL/SLC Class 1 01-10-2007 08:43 AM
    Raw fuel from tailpipes...lead foot condition or... Guest (MBNZ) W124 E,CE,D,TD Class 0 08-07-2002 06:47 AM
