coolant drain and refill - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-19-2007, 11:34 AM Thread Starter
Date registered: Jul 2007
Has anyone done a coolant drain and refill? Do you use MB antifreeze? I have an ML55 with no drain cocks. How do you drain your system?
russ1 is offline
post #2 of 7 (permalink) Old 12-19-2007, 11:46 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Is it a 163.174 with 113 engine? I guess on this one you should drain from the lower coolant hose (detach it). Should use MB coolant (mixed as advised) unless you are absolutely sure the other type is correct for this engine.
Diesel Benz is offline
post #3 of 7 (permalink) Old 12-19-2007, 02:09 PM
Dukester's Avatar
Date registered: Nov 2007
Vehicle: Silver 1998 S500
Russ1, the only alternative to MB coolant is Xerex G-05. Xerex manufactures the coolant MB puts in their grey containers and the G-05 version is approved by MB. I've seen it in Autozone & Checker parts stores.
I would also recommend mixing it with DISTILLED water versus tap water. This will keep minerals out of your cooling system.
Dukester is offline
post #4 of 7 (permalink) Old 12-19-2007, 02:50 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
Distilled water at Wallmart is 70 cents a gallon. You don't want to screw up $25 coolant for saving 70 cents?
I pulled lower hose on our ML55 but it was a cut on upper hose, that made me changing coolant.
As stated in another topic, MB coolants are 15years/100,000 miles coolants. What is your ML55 age?
Kajtek1 is offline
post #5 of 7 (permalink) Old 12-20-2007, 04:28 AM Thread Starter
It is 7 years old with 101000 miles.
russ1 is offline
post #6 of 7 (permalink) Old 12-20-2007, 09:43 AM
Kajtek1's Avatar
Check the hoses before changing the coolant. If they show any aging, it is advisable to replace them. Especially the lower one.
Kajtek1 is offline
post #7 of 7 (permalink) Old 01-24-2008, 11:09 PM
Asterisk's Avatar
Date registered: Jan 2008
Vehicle: 1996 Mercedes Benz C 220
Hmm, so 70cent distilled water it is! Search button FTW!
Asterisk is offline
    Transmission flush or drain and refill patsslk R170 SLK-Class 14 09-17-2007 11:04 PM
    Coolant drain plug tbsi430 C208/A208 CLK-Class 5 12-05-2006 10:08 AM
    1973 404 transmission drain/refill someotherguy Unimog 7 10-04-2005 02:45 PM
    did my 20k tranny fluid drain and refill... snik W140 S-Class 6 06-03-2004 12:01 PM
    Where is the coolant drain plug? twalter W210 E-Class 1 12-30-2003 11:16 AM
