A class steering angle sensor - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-18-2007, 07:18 AM Thread Starter
perryhawk's Avatar
Date registered: Dec 2007
Exclamation A class steering angle sensor
Hi all, does anyone have any tech spec or pictures for the assembly of the steering column?
I have an ABS, BAS & EPS light on which has led me to a steering angle sensor fault. I have changed the sensor and the squib but the air gap i can see between them is excessive and I am unable to see how to rectify this. Can anyone assist?
perryhawk is offline
post #2 of 2 (permalink) Old 12-18-2007, 08:28 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
I'm not familiar with an A but is it a 168 or 169 car (which MY?). The steering angle sensor is using photoelectric sensors and a gap clock spring contact and steering angle sensor parts should be natural, as long as the blades reach to block the light.
Or do you mean the contact springs for the airbag/horn? But that should not be ABS/BAS/ESP related?
Did you remember to normalise the sensor after repair work?
Diesel Benz is offline
    stearing angle sensor gravel W163 M-Class 9 12-03-2014 01:45 PM
    92 600SL steering angle sensor fault StuartKnight R129 SL-Class 0 01-23-2007 12:00 AM
    Steering wheel off angle now. Where to look for the problem? AlanMcR G-Class 23 06-26-2006 09:49 AM
    Steering angle replacement? stespa R129 SL-Class 0 11-08-2005 10:02 PM
    How do I get to the Steering angle sensor? tomtoth W124 E,CE,D,TD Class 1 07-29-2004 08:35 PM
