Help needed.. drained the ATF by accident on a 99 CLK 320 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 12-15-2007, 10:36 AM Thread Starter
Date registered: Nov 2007
All,
In my haste I removed the drain plug for the ATF in error and lost the pan's quantity of fluid.
I've found many articles on the subject of changing the fluid but can't find any pictures on where the dipstick or top up hole is located for this particular engine/gearbox.
Can anyone help with pictures or a link to pictures.
Please also advise on the correct fluid - Dextron III seems to be talked about.
Thanks in advance
Matt
super fandango is offline
post #2 of 11 (permalink) Old 12-15-2007, 12:37 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Where did you drain the tranny if you didn't do it from the tranny dipstick tube?
I assume this tranny has a dipstick tube without a dipstick in it. Just a cap with a protection clip, intended to avoid draining oil by accident, instead of the engine.
Probably not bad to change the tranny oil, but the fill up procedure isn't equally simple as for the engine. You wold need a dipstick tool, fill first a specific amount of oil, let the engine run and measure it at two temperatures.
If you are not sure about the correct oil, why not buy from the dealer.
Diesel Benz is offline
post #3 of 11 (permalink) Old 12-15-2007, 12:42 PM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
If you use anyother kind of tranny fluid but MB fluid your asking for trouble. Spend the extra cash and get the right stuff.
livefreeordie is offline
post #4 of 11 (permalink) Old 12-15-2007, 01:00 PM Thread Starter
I accidentally removed the drain plug on the transmission sump (1/3rd way down the car) not the engine sump as planned.
Have now managed to change the oil but my transmission is now a good few litres short of fluid.
post #5 of 11 (permalink) Old 12-15-2007, 01:27 PM
Quoted: 35 Post(s)
What about putting new oil approximately as you drained and drive carefully to a shop to have it checked? Or drive another car to the dealer, buy the oil and borrow the tranny dipstick tool? Perhaps let them check the tranny when you give the tool back.
post #6 of 11 (permalink) Old 12-15-2007, 01:34 PM Thread Starter
I will put the tranny oil in but I don't know where it goes, hence the post.
Any ideas?
post #7 of 11 (permalink) Old 12-15-2007, 01:37 PM
If its a LHD the tranny tube is on the right side( driver side) the cap is black with a red tab. Once you break the tab you will need a new filler cap. Also don't expect to find a dipstick you will have to borrow or buy one.
post #8 of 11 (permalink) Old 12-16-2007, 12:45 AM
Quoted: 35 Post(s)
I see he really did drain from the wrong plug, that is what he wrote but the typical mistake is to siphon from the wrong tube. When removing the tranny dipstick tube cap, first remove the locking pin at one side, lift it up, this releases the cap itself.
post #9 of 11 (permalink) Old 12-17-2007, 09:14 PM
Date registered: Dec 2007
I have the same problem at the moment. I am trying to locate the filler tube for a C240 2002 (ATF). Thanks.
abinuya11 is offline
post #10 of 11 (permalink) Old 12-18-2007, 02:39 PM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
Have you looked in a manual ?
You will also need a deep stick (available at dealer) or if you can find measurements of deep stick (low and high points) - you can make the deep stick yourself.
Kirill
Kirill is offline
    CLK 320 Service Needed Light -- help stasha General Mercedes-Benz 2 07-09-2007 04:06 AM
    1998 ml 320 accident randomtask General Mercedes-Benz 7 01-22-2007 06:11 PM
    Common Warranty Repair Needed 320 CLK judykay C209/A209 CLK-Class 0 09-04-2006 04:42 PM
    Owner opinions needed 1998-1999 CLK-320. NY153 C208/A208 CLK-Class 2 07-21-2005 08:15 AM
    ATF Dipstick/ ATF Fluid Change and Electronic Transmission JNLeChevet W140 S-Class 1 03-02-2005 08:30 AM
