02 E320 Headlamp washers - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-14-2007, 06:39 PM Thread Starter
Date registered: Dec 2007
Vehicle: 02 E320 4Matic
Send a message via Yahoo to gubbio
One of my headlamp washers stopped working today. I have checked the fuses and they are fine. Any troubleshooting tips? Thanks!!!
gubbio is offline
post #2 of 2 (permalink) Old 12-14-2007, 10:31 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
Its likely a clogged or leaking water line at the side that failed. Even the pop up part of the washer is driven by water pressure and if only one side has failed that means the pump and wiring is not the problem.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
    Headlamp Washers AK Benz W211 E-Class 5 02-07-2008 04:34 AM
    windscreen washers papa R170 SLK-Class 1 12-02-2007 08:28 PM
    headlamp washers JimmyD89 W126 S,SE,SEC,SEL,SD,SDL Class 5 12-06-2006 04:26 AM
    Changing Headlamp, 98 E320 rac43 W210 E-Class 1 03-12-2004 09:01 AM
    97 E320 Xenon Headlamp Upgrade Guest (MBNZ) W210 E-Class 6 06-08-2001 02:29 PM
