W210 control arm bushing check - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-14-2007, 06:37 PM Thread Starter
Date registered: Dec 2007
How does one tell when the front lower control arm bushings are in need of replacement? There appear to be hard bushings at the rear of the arm and soft in front. Using a crowbar, the hard do not move at all and the front can be moved but return to center. All look in good shape. I am getting strange tire wear on the inside corners of the front tires, almost on the sidewall. The alignment has been checked twice. Before spending the $600 to replace the bushings I'd like to know how to check them. My car is a 99 with 100k.
Lobengula is offline
post #2 of 2 (permalink) Old 12-15-2007, 12:22 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
I would lift the front of the car, it is pretty difficult to see the wear if the wheels have load. Even the anti-roll bar may make it difficult, that is why it is better to lift the front, or the rear completely.
Diesel Benz is offline
    Need Lower Control Arm Bushing Replaced RichRocky R170 SLK-Class 10 04-23-2010 08:36 PM
    Replacing lower control arm bushing IM4DHERD R/C107 SL/SLC Class 3 01-30-2007 07:56 PM
    Changing lower control arm bushing IM4DHERD The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-04-2007 05:52 PM
    Broken Upper Control Arm Bushing Big D W126 S,SE,SEC,SEL,SD,SDL Class 3 09-07-2005 11:10 AM
    control arm bushing vdubpower W140 S-Class 13 12-20-2004 06:51 AM
