Battery/Alternator light - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-05-2007, 01:54 AM Thread Starter
Date registered: Nov 2007
Question Battery/Alternator light
I have a C200K Sport Coupe (2002) and recently the battery/alternator light comes on and off intermitently. My garage says they can't find anything wrong with the belt or tensioner and to run it till the light comes on permanently. Anyone else have/had the same problem and what was the resolution.
codemonkey is offline
post #2 of 4 (permalink) Old 12-05-2007, 01:57 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
usually the alternator will intermittently fail on the car. try first by replacing the voltage regulator
Streetglower is offline
post #3 of 4 (permalink) Old 12-05-2007, 06:11 AM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 249 Post(s)
The alternator has carbon brushes in it that run against the armature. The entire assembly is held on to the rear of the alternator by two screws. You might want to remove the plug that connects the alternator to the circuit (also on the rear of the alternator) and then remove the assembly with the brushes, transistor, etc. Take a look at the brushes to see if they are shot. Sometimes they are jammed up with carbon and road dirt, etc. Blow out the assembly with air and see if the brushes move freely in and out. You might want to stretch the spring that loads the brushes outward because if the brush is low on spring pressure and worn significantly, it won't reach the armature with any real pressure and cause an intermittent connection and the problem you are having. The long term fix is to replace the brush assembly or to have the alternator rebuilt. Good luck
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #4 of 4 (permalink) Old 12-05-2007, 03:12 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
The brushes tuttebenne mentions are part of the voltage regulator assembly, under $100 but you have to know if you have the valeo or bosch unit -- at least in the US market. In the US there was a voltage regulator recall that spanned a few years and a few models (although not all by any means), since you're in Europe (I'd guess based on the engine) you'd have to see if it is in effect over there. (While we're on the subject, please update your BW profile re: vehicle and location, that information can be quite useful.)
If you're in the DIY mindset you'd want to disconnect the battery before you go pulling the alternator or the regulator.
Take care and enjoy the ride,
Greg
Check Codes is offline
    Alternator or Battery? icedtrip R/C107 SL/SLC Class 23 11-05-2007 09:05 AM
    Battery or Alternator??? juancpath C208/A208 CLK-Class 14 07-21-2007 01:29 AM
    Battery or Alternator pathogen W126 S,SE,SEC,SEL,SD,SDL Class 6 02-25-2007 08:09 AM
    Is it my battery or the alternator?? baker462 Vintage Mercedes-Benz 8 02-01-2007 11:00 PM
    Fault battery/alternator and head light problems. Pyrotech W203 C-Class 0 06-16-2006 08:09 PM
