1998 S 420 Oil Filter - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 12-02-2007, 03:14 PM Thread Starter
Date registered: Dec 2007
I went to have the oil changed yesterday and the guy says he could not change the oil filter because he could not remove the top of the oil filter canister. He showed me the problem. It seems that the motor had shifted to the right somehow enough to not allow access to the oil filter canister. Does anyone have any ideas what the problem can be?
rjicard is offline
post #2 of 13 (permalink) Old 12-02-2007, 03:49 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Bad mounts?
Kajtek1 is offline
post #3 of 13 (permalink) Old 12-02-2007, 04:45 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
All of your motor/trans mounts must be collapsed. Do you care for this car or is Jiffy Lube your mechanic? How could you not notice?
mr.xpowerseller is offline
post #4 of 13 (permalink) Old 12-02-2007, 05:18 PM
Date registered: Jul 2004
Quoted: 310 Post(s)
Motor mounts can sink a bit without generating the symptoms of completely failed motor mounts. In any case you need to get new ones. If your engine isn't shaking at idle it's not that critical. You can change the oil without changing the filter which I guess is what's already happened.
deanyel is offline
post #5 of 13 (permalink) Old 12-03-2007, 05:59 PM Thread Starter
Thanks, the more I read the more I'm sure it's the mounts, at least the right one is bad.
rjicard is offline
post #6 of 13 (permalink) Old 12-03-2007, 06:02 PM Thread Starter
thanks for your answer, obviously it isn't bad enough for me to really notice. This is my wife's car. I stay pretty busy with my MOPAR muscle cars...Believe me this car is well cared for...no, Jiffy Lube is not on my list of specialty vendors.
rjicard is offline
post #7 of 13 (permalink) Old 12-03-2007, 06:16 PM Thread Starter
Thanks for your response. I suspect you are right. My wife has not complained of any vibration or noises and believe me she would. This is her baby! I'll do some close checking this weekend. I have a lift I can put it up on and check it out. Would this be a DIY job or an expensive MB dealer job?
rjicard is offline
post #8 of 13 (permalink) Old 12-03-2007, 07:13 PM
~BANNED~
Both mounts would have had to have collapsed if the engine shifted as much as you say. Anyone would notice that while driving the car. The engine would vibrate the car beyond reason. Bring it back to Jiffy Lube and let their 'mechanics' have a hand at it.
post #9 of 13 (permalink) Old 12-03-2007, 08:28 PM
Quoted: 310 Post(s)
It's potentially a DIY job, especially if you have a lift. It is tight on the V8s and you may need to remove some things to get at it, perhaps the exhaust pipe on the driver's side. Once you get the bottom bolts out you need to raise the engine about 4 or 5 inches. If you can break the top bolts loose you're pretty much home free.
deanyel is offline
post #10 of 13 (permalink) Old 12-03-2007, 09:03 PM
W140FTW's Avatar
Date registered: Nov 2007
Vehicle: 1999 Mercedes Benz S320 Long Wheelbase.
Send a message via AIM to W140FTW
Yeah....and have John Wayne Gacy babysit your 8 year old....
W140FTW is offline
    Can I use 1998 E-320 instrument cluster on 1997 E-420 hadam W210 E-Class 2 10-10-2007 10:18 PM
    C220 maintenance Q's (auto tranny fluid, filter) (oil viscosisty and filter) C220Heb W202 C-Class 4 03-20-2007 02:32 PM
    1998 S 420 for sale.... The Workshop MB For Sale/Wanted/Trade/Giveaway 0 10-09-2006 10:43 PM
    Q: crossfire oil filter VS slk oil filter...same?? viken R170 SLK-Class 1 10-08-2003 07:19 PM
    Any one know difference between euro and us model for oil filter?slk230-1998 SIMON R170 SLK-Class 1 08-16-2001 02:58 PM
