Do I need any special tools to change the brakes and rotors on a 2005 c230. Is there a place where I can get step by step details? Any tips would be helpful.
Hey, Dune, welcome to the forum. Please complete your BW profile se vehicle and location as that can prove very helpful.
You may not have realized it but there is a forum specific to your W203. Just scroll down the main page and you will see it. Any time you have a question that is about your car in particular that is the best place to post such questions. This general forum is more -- general.
I am certain the folks there will have the knowledge you seek.
Take care and enjoy the ride,
Greg
__________________ When you learn from your own mistakes, that's experience.
You should not have SBC on a c class. For the the pads and rotors you will need a T30 to remove the screw holding the rotors on, a T45 or 8allen(dont remember which) and a 18mm socket, also calipers presses, and a bungie cord to hang the caliper. I also recommend a large hammer to remove the rotor as they are usually rusted on pretty good. To tell if you have SBC the hydraulic unit under the hood with all of the brake lines going out of it will say SBC on it if you have SBC also it will have an accumilator on the bottom of the pump. If you do not have SBC then this unit will only say ESP and will not have an accumilator.
only the e, sl, and cls have sbc so dont worry about that. is your car standard or sport. if its standard you need either a 12mm or 13mm socket for the brake caliper. a 18mm socket for the calipers and a t30 torx for the rotors. and a trusty BFH never hurt for gettin the damn rotors off. other than that its straight forward. only difference for the sprt is you only need a punch and a hammer to remove the pads.
mine (C230 Sport) is due for replacement - front rotors and pads, dealer gave me $740.00 for the job. is it worth to DIY the break system? how much did all the parts cost?
