radio says (wait) - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 11-22-2007, 11:43 AM Thread Starter
Date registered: Nov 2007
Vehicle: W124 300CE
Post radio says (wait)
I just purchased a 1990 300CE nice... very nice. anyways the automatic antenna would not fully extend and that is why (I assumed) when ever I turned the radio on it would say (wait) and nothing else. so I took it off, and am in the process of replacing it BTW if anyone has a working antenna from a 124 chasis I'd like to puchase it. Well back to it, and even when I put in a tape all it does is say (wait) and no buttons work except for the on/off button. Can anyone point me in the right direction, I need tunes!!!!!!!!!!!!!
captain137 is offline
post #2 of 10 (permalink) Old 11-22-2007, 11:51 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
You would have to follow the advice, wait until the radio requests the security code. I'm afraid you might not have it, do you have all the car documents available, look for a small sticker with 4 or 5 digit code and even better if you can find the radio manual that tells how to enter the code.
If you can't find the code, a dealer should be able to give it to you (against proof of ownership).
Diesel Benz is offline
post #3 of 10 (permalink) Old 11-22-2007, 02:52 PM Thread Starter
Vehicle: W124 300CE
captian137
hey thanks alot like i said i'm new to this mercedes thing and i think that signing up for Benzworld.org was probably the smartest move yet. I'll be looking for tech advice later.
post #4 of 10 (permalink) Old 11-22-2007, 03:40 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Someone entered before wrong code 3 times and radio is in wait-out mode before allowing new entry. Usually it takes about 30 minutes with radio on to wait out.
Good luck on finding the code.
Kajtek1 is offline
post #5 of 10 (permalink) Old 11-27-2007, 06:23 AM Thread Starter
Vehicle: W124 300CE
but I've ridden around for like an hour and it still says wait. I called a dealership and they said that the only way to get the code is to get the serial# off the back of the radio. If I do that and put in the code while it still says wait will it work or do I have to wait untill it doesnt say wait anymore? ok and next thing^ my, I guess, automatic belt tensioner squeels on cold days for awhile, even after the car has warmed up to 80'C (which i've payed attention to and the car doesn't get any hotter) is there anything I can put on the tensioner to make it stop or should I just replace it?
post #6 of 10 (permalink) Old 11-27-2007, 07:18 AM
Quoted: 37 Post(s)
Don't know about the belt tensioner. The radio may need to be on (ignition on) up to 24 hours, depending on the model. If it is the original radio for this car, the dealer should be able to give the code from your VIN, otherwise the radio serial number is needed. You would have to pull the radio out to see the SN.
Might anyway be simpler to take the radio out and have it connected to a power source. Once the correct code has been entered, you would have to re-enter it when putting it back but would not have to wait any more.
post #7 of 10 (permalink) Old 11-27-2007, 01:37 PM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 68 Post(s)
That's exactly what I did for my fathers 190E. I left the radio turned on on my work bench on a spare 12V battery. 23 - 24 hours later I could enter the code. Once the code is accepted I returned the radio to his car and re-entered the code.
I think this 24 hour thing is not realized by many who try more than 3 times to enter their code.
Also I don't appreciate all those who are giving out radio codes on this forum. It's well known that many stolen Mercedes radios are sold on Ebay. The codes are readily available at any dealer and I have never heard of anyone being charged for a radio code. However it is funny reading some of the sob stories people give for not going to their dealer.
Mike
Mike's ML is offline
post #8 of 10 (permalink) Old 11-27-2007, 02:22 PM
Kajtek1's Avatar
I lost the code on our sedan due the bad battery. The VIN number produced wrong code, so I put the radio in "wait" mode. From what I recall it took like 1 hr to clear, but than I was driving for over a week before going back to the dealer.
The counter person pulled the radio for me and read the serial number for no charge.
Get the belt tensioner replaced soon. Consequences of it going bad might be not only costly, but also inconvenient.
Kajtek1 is offline
post #9 of 10 (permalink) Old 11-27-2007, 10:02 PM
Quoted: 37 Post(s)
At least for one W124 radio model the time to wait for a new code entry was 15 minutes. Then the workshop manual says the radio gets "completely locked after three incorrect attempts", but continued, "the code can only be entered again after having power on circuits 15 and 30 for 24 hours".
Don't know why the VIN based code isn't always right but a good point to make note of. The older radios are also so easy to pull out if the serial number needs to be read.
post #10 of 10 (permalink) Old 11-27-2007, 10:27 PM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
Your belt tensioner may not be the problem, check your belts first.If you see any cracks replace them, when a belt squeals its stretched out and needs to be replaced.
livefreeordie is offline
    Radio in WAIT! mode Evan W124 E,CE,D,TD Class 3 09-17-2008 01:26 PM
    Becker radio still says WAIT 1985 300CD W124 E,CE,D,TD Class 2 11-28-2007 03:57 AM
    Removing WAIT from radio mbplus Audio & Telematics Forum 18 10-28-2007 11:01 PM
    Need New Radio Code to Clear wait ! Flamenco2005 R129 SL-Class 11 07-27-2007 01:46 PM
    1990 560sel radio says "wait" MB1990 Audio & Telematics Forum 0 10-30-2004 06:25 AM
