what' happen if i dont mix coolant with water? - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 11-20-2007, 01:51 PM
g.w.b's Avatar
Date registered: Dec 2006
Vehicle: 300D
Send a message via MSN to g.w.b Send a message via Yahoo to g.w.b
Originally Posted by benmed View Post
Thanks, what do you mean by this " it is no good fore the water pipes of your car neat"? would you please explain!
what should i do to reset the message "check coolant" because i just fill up and it is full. i read owner manual and try to do it but the message still there. Thanks
Coolant alone doesn't cool as efficiently and coolant alone is bad for your water pips it eats through the rubber in the long term
1991 160 monza (100 259 km)
1974 w116 300D (890 000 km)
g.w.b is offline
post #12 of 14 (permalink) Old 11-20-2007, 02:23 PM
Date registered: Sep 2006
Vehicle: 2015 S550 222
Send a message via AIM to platt-deutsch
If you mix the anti-freeze any stronger than 50% coolant with 50% water it will not absorb heat from the engine properly and will not be good for the engine as hot spots will develop.
Be sure it is not already diluted to 50% in the jug. It will tell you to mix it 50% if it is not already diluted.
platt-deutsch is offline
post #13 of 14 (permalink) Old 11-20-2007, 04:14 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
You need to go to a different garage/shop and have them do this correctly. This is obviously way over your head. If you talk along the lines of how you write, I can't see how the "service part man" could possibly understand what you are saying.
mr.xpowerseller is offline
post #14 of 14 (permalink) Old 11-20-2007, 10:31 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
i just called servive part man about coolant, he confirm me that is correct coolant, however he dont know anything about the different color??? did distill water (inside reserve tank) do any harm to the sensor or the residue cover the sensor?? please tell me the location of the sensor and how to check it please!!!
The coolant type is usually marked with one specific colour. Perhaps the car did not have the correct coolant type before you changed it.
The coolant level sensor should be at the expansion reservoir.
Diesel Benz is offline
    why beer and fireworks just dont mix dklein Off-Topic 4 03-14-2007 03:14 AM
    Puddle & SLK dont mix... vincent007 R171 SLK-Class 24 09-17-2006 04:07 PM
    Dogs and SLK's Dont Mix luv_my_benz R171 SLK-Class 3 05-15-2005 07:45 PM
    Oil & Water Mix AL-Sayegh W140 S-Class 6 03-03-2005 03:32 AM
    i dont know if this ever happen to you guys, but since my last service which was about two... BOY-6 W163 M-Class 1 06-02-2003 12:27 PM
