c240, 2003, power steering refill location - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-15-2007, 03:32 PM Thread Starter
Date registered: Nov 2007
would you please tell me the location of power steering refill location and location of transmission oil drain plug. i have tried to search the forum but i did not find the specific answer to my question yet, please help me! Thanks!
benmed is offline
post #2 of 5 (permalink) Old 11-15-2007, 03:53 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
The power steering oil reservoir should be at the front left (to your right if you look at the car from the front) of the engine bay. You should find it at the power steering pump driven by the poly belt. A small box with a cap with a dipstick.
This car would have a drain plug at the bottom of the tranny but are you sure you should do the service yourself, the position of the plug isn't the most difficult and important point for the task?
Diesel Benz is offline
post #3 of 5 (permalink) Old 11-15-2007, 05:42 PM Thread Starter
Thanks Diesel Benz!!! i am not with my car right now but i will find it the evening! yes i would like to just drain transmission oil and and put in a new oil so i really want to know where it is. i don't have alot money however i really like mercedes so i really want to maintain it in good condition and would like to be able to do as much care as possible to make my car happy! as well as me! if you have chance would please explain to me how to change transmission oil and tell me location of transmission oil refill! i am very new and dumb if you explain please explain in detail as much as possible! thanks again i had look for power steering for years under the hood, hope you dont laught at me!
benmed is offline
post #4 of 5 (permalink) Old 11-15-2007, 05:53 PM Thread Starter
when i am under the car which portion of the engine is transmission portion? in order to find transmission drain plug! Thanks!
benmed is offline
post #5 of 5 (permalink) Old 11-15-2007, 07:09 PM
Quoted: 35 Post(s)
I'm still a bit puzzled if you should try to perform a DIY service with the tranny. The tranny anyway is the box between the engine and the cardan shaft. I guess you have noticed that your car is rear wheel driven.
Have you removed the plastic covers from the bottom, from behind the engine (not sure how the parts are sectioned in your car)?
I don't have any public references at hand, you could see the W211 documentation although it is for a different tranny:
http://www.mercedestechstore.com/pdf...9%20062504.pdf
En example how the tranny should look like.
    power steering refill location? planetmuzik W116 S, SE, SEL, SD Class 2 04-05-2007 09:02 AM
    1986 560 SEL Power Steering Fluid Location element2012 W126 S,SE,SEC,SEL,SD,SDL Class 3 12-09-2006 07:46 PM
    400SEL Power Steering Refill IsleSeat W140 S-Class 1 11-22-2006 06:42 AM
    What is the correct fluid for and location of the power steering filter for a 1990 300 SEL? ACB General Mercedes-Benz 1 05-06-2005 08:17 PM
    Power Steering Fluid location 500 SEC Ecol W126 S,SE,SEC,SEL,SD,SDL Class 1 12-18-2004 07:40 AM
