ticking from torque converter - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-12-2007, 07:10 PM Thread Starter
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
i have a 97 e320, 140k miles with the 722.6 transsmision. for a while now, sometimes in cold starts (when it's cold) i hear this little ticking from underneath the car. you have to concentrate in order to listen to it. at first i thought it was coming from the engine, an oil lifter or maybe the air pump. i had my mechanic listen to it and he traced the noise from the torque converter, but everything looked fine there, no leaks and he tightened the bolts more to see if the noise would go away. the car shifts and drives smooth like it did 10 years ago, no codes, everything seems good.
what do you guys think, what could this be???
tirona is offline
post #2 of 5 (permalink) Old 11-16-2007, 11:52 AM Thread Starter
tirona is offline
post #3 of 5 (permalink) Old 11-16-2007, 11:59 AM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
ive have never seen a torque converter tick um is he sure of wheres its coming from? cause that sound strange. because if somthing was coming in contact with the converter to make a ticking noise you would be able to see it. i would check the cat converter to see if it;s hitting the fram at any point. that is a common problem with ml's and it could resinate into the trans.
mike
"MERCEDES BENZ LIKE NO OTHER"
ctbenztech is offline
post #4 of 5 (permalink) Old 11-16-2007, 12:18 PM
Date registered: Oct 2007
It could also be the exaust pipe or catilitic converter or muffler heating up. I know first hand that the catilitic converter will tick when they are cooling down.
'91 MB 300E 2.6
'01 Nissan Exterra v6
'04 Jeep Cherokee limited 6cyl
Computers are like air conditioners, they work great untill you open windows.
tincan is offline
post #5 of 5 (permalink) Old 11-17-2007, 01:17 PM Thread Starter
thank you guys for your replies. it does make sense what you are saying about the noise coming from the cats.
tirona is offline
    Torque converter Oscar58 W210 E50 AMG, E55 AMG 1 11-24-2005 08:40 PM
    Torque converter Oscar58 W210 E-Class 2 11-23-2005 06:50 AM
    Torque converter onesixthree W163 M-Class 3 09-14-2005 12:50 PM
    Torque converter cj3a Unimog 9 05-26-2005 08:08 AM
    Fan Ticking on high torque low revs Guest (MBNZ) W201 190-Class 1 10-09-2001 05:14 PM
