Anti skid & limp mode! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-10-2007, 08:44 PM Thread Starter
Date registered: Nov 2007
Vehicle: CLK320 sport
Question Anti skid & limp mode!
I fear I have a major problem looming, someone please tell me otherwise. I own a 1999 CLK 320 sport with very low milage for the year (30,000miles)
The intermittant problem I have with the car has two distingtive symptoms. Firstly the speed of the car is restricted to approx 60mph, the engine still revs to full capacity but does not transfer the torque to the road wheels. Also the auto transmission will excellerate up to 60mph as if it is in kickdown. When the ignition is turned off and then the engine is restarted after approx 10 seconds the problem clears & away we go. During this time there are no alarms visable on the dash.
The second set of symptoms are a little more dramatic. The anti skid alarm initiates, the drivers air bag warning light comes on, the speed drops to approx 10mph and the engine appears to partially shut down to the extent that it is only running on 3 cylinders. The cure appears to be the same, stop the engine, wait 10 seconds then restart. The time span between the first & second symptoms is within a couple of days of each other, at the moment there appears to be approx 300 miles between them repeating. Can anyone help??
CLK320rob is offline
post #2 of 3 (permalink) Old 11-13-2007, 04:07 AM Thread Starter
Thumbs up Result - hope so!!
Is it sad to be the first to reply to your own thread? Just thought I would give an update. Had a diaganostics done and it was traced to non other than the brake peddle switch. Hope this info is of help to someone out there.
If you you live in the Midlands area of the U.K then I no a man who knows his stuff, Details below.
Perrys Autospark - Mobile: 07710664351
He hails from the Cannock area and is mobile so can travel to your home or work place.
post #3 of 3 (permalink) Old 11-13-2007, 09:29 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
This happens often, one gets a resolution from oneself
This should actually happen more often, as you say, it would be useful for others to know how the issue was solved, irrespectively how and who figured it out.
Thanks for posting.
Diesel Benz is offline
    Limp Mode noelchambers R170 SLK-Class 4 08-18-2008 01:27 PM
    LIMP MODE djblu R129 SL-Class 12 08-14-2007 05:21 PM
    HELP!! .. limp mode! BenzSLK230 R170 SLK-Class 7 06-12-2006 09:23 AM
    limp mode??? Dolphin27 R170 SLK-Class 1 01-04-2006 03:02 PM
    What is "limp mode"? xraider W202 C-Class 1 02-23-2004 05:20 AM
