c43 windows work intermittenly?????? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-09-2007, 10:21 PM Thread Starter
Date registered: Oct 2006
My front windows are loosing touch here. the power mirror stops working on the driver side and so does the mirror wiggle the fuse and viola they work, not sure what is going on, anyone else have simular problems? I tried the search but nothing
Outlaw Latemodel is offline
post #2 of 5 (permalink) Old 11-10-2007, 12:18 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, OLM.
That's a new one on me. Just a couple of thoughts, hopefully they'll point you in the right direction if you don't hear from someone who's suffered through this.
First, seems like whenever there arises an odd electrical issue it is worth trying the 'Windows' approach and rebooting. Be sure you have your radio code and them disconnect the neg. battery cable, wait a bit and then reconnect it. Go through all the resets and see if that helps.
If not, wiggling the fuse suggests a couple of things, either a loose wire, a loose connection or a defective fuse. Easiest thing is to just replace it simply to eliminate that as a possibility. Then start working backwards from there. It is also possible that the connection issue is at the relay and by wiggling the fuse you cause an intermittent current disruption that results in a 'mini-arc' and - temporarily - closes the circuit.
Anyway, those are my initial thoughts, hope they prove to be of some use.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 5 (permalink) Old 11-18-2007, 11:28 AM Thread Starter
gregs210 thanks for your advise ill try the reboot thing, i can seem to be able to tell if there is a relay involved with this, I havent heard of the reboot thing before though, Thanks,
post #4 of 5 (permalink) Old 11-22-2007, 03:12 PM Thread Starter
rebooted worked for a day yep same ol same ol, anyway is there a window relay? Kevin
post #5 of 5 (permalink) Old 04-15-2008, 02:54 PM
Date registered: Nov 2007
c43 window problem
Wow - timing is everything. I am having the same problems with my 99 C43 with 99K miles. It seems to affect either the front drivers or passengers window and side mirror (or once in a while) both at the same time. I re-boot the car by momentarily taking the cable off the negative battery terminal and wallah.... it mysteriously works again. In addition, the front 2 windows one touch feature (window all the way up or down) does not work. To roll the window down (or up), I need to keep holding the window button on the first detent of the toggle switch. Anybody else out there experienced this, or knows what might be amiss?
dc
davidrcarls is offline
    Windows Won't Work Euro280SL W163 M-Class 2 08-23-2007 04:17 PM
    All 4 windows work!! DieselBear W123 E,CE,D,CD,TD,TE Class 3 03-03-2007 02:56 PM
    Lights alarm go off intermittenly! Help? fastmike99 General Mercedes-Benz 0 08-31-2006 10:44 AM
    Can't get any of my windows to work! Skeeter W123 E,CE,D,CD,TD,TE Class 23 05-21-2006 01:46 AM
    Glowplug light coming on intermittenly Adam_SD W140 S-Class 1 07-14-2005 12:54 PM
