MB oil filter or aftermarket - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 11-07-2007, 08:19 AM Thread Starter
Date registered: Nov 2007
Vehicle: 2011 nML 350
Hello everyone I'm new to the forum, My wife drives a 05 240 that we bought new in late 04 and all this time my wife has made the apointments to have the old changed and other things so I had no idea what it was costing me to change the oil on the car will this time I called and they want $320.00 to change the oil and do a few other things, I think thats nuts.
Well I'm going to be doing the oil changes from now on, but I'm not sure if I should buy the MB oil filter or buy the Fram one, what do you think? I will be using the same oil that I use on my other cars the Mobil 1 full syn, I'm just not sure about the filter, I was told that the filter is why you only need to change the oil onces a year.
Thanks for your help.
RubenJ is offline
post #2 of 12 (permalink) Old 11-07-2007, 10:57 AM
Date registered: Mar 2007
Vehicle: 2007 Alpine Rain/Ash ML320 CDI
I am not a Fram fan and have found through the years that many oil filters are made by the same company and sold at varying prices under different names. On my domestic cars I actually use the Walmart brand which is good quality and the same as an STP (and others). I would recommend visiting the Germanfilters.com web site. Their prices are good and I've found their customer service to be excellent.
CJzBenz is offline
post #3 of 12 (permalink) Old 11-07-2007, 11:49 AM
Date registered: Feb 2005
Vehicle: 96 SL500, 97 E420,
Quoted: 6 Post(s)
Send a message via Yahoo to gqmagic
I pay $68 for oil changes
$5 x 8 for Mobil 1
$8 x 1 filter from Autohauz Arizona
$20 labor
gqmagic is offline
post #4 of 12 (permalink) Old 11-07-2007, 12:02 PM
Punjabi's Avatar
Vehicle: Bandwidth
'Fram' filters are pretty good and should do in lieu of the MB (Note! MB don't make filters, just pack them in their glossy carton and charge you for honour!)
Don't skimp on the oil - buy the best spec suited to your engine!
Punjabi is offline
post #5 of 12 (permalink) Old 11-07-2007, 01:09 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Use the filter recommended by MB ONLY! Not sure what they recommend for your wife's car, but on mine they say use only Fleece filters and I do. This is not an item to skimp on. And especially if you're using Synthetic oil like Mobil 1 you really don't want to mess w/ a Fram filter, IMO.
Don't believe everything you think
Jayhawk is offline
post #6 of 12 (permalink) Old 11-07-2007, 03:17 PM
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Hear hear.
If I were you, I will take both the post above and this advice below with a grain of salt.
Originally Posted by lkchris
You absolutely/positively cannot improve on Mercedes brakes by changing pads or rotors from OE specification.
mlfun is offline
post #7 of 12 (permalink) Old 11-07-2007, 04:36 PM
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2013 VW Golf Sportwagen TDI, 2011 Mazda 2, 2000 E320 4Matic Wagon (retired),1994 C280 (retired)
Avoid the Fram filter. When you open them up, at least the spin-on variety, you can clearly see that there are fewer pleats of filter paper, which means less filter paper surface area to filter your oil. The filter paper they use is also more porous than other makes, which allows more stuff to pass through the filter element that you might want the filter to catch. You might save a couple of bucks on the Fram vs. the original equipment filter, but is that couple of bucks worth it in the long run?
jlomon is offline
post #8 of 12 (permalink) Old 11-07-2007, 05:10 PM Thread Starter
Thank you, I guess I will be buying the MB filter.
Thanks again.
RubenJ is offline
post #9 of 12 (permalink) Old 11-07-2007, 06:32 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 752 Post(s)
I would also avoid Fram and stick to OEM brands such as Hengst, Mann and Knecht.
GeeS is offline
post #10 of 12 (permalink) Old 11-07-2007, 06:46 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Thanks again.
Hi, Ruben, and welcome to the forum. Another point that has been dodged about in here is that the newer cars require the fleece filter. While I've seen a bunch of generic filters for MB's (including NAPA and Fram), they have always been the paper element. The only fleece I've found are the OEM/OES manufacturers, names referenced by Ron in the post above.
And qmagic is able to buy the less expensive Mobil1 because his car didn't spec the newer variety, 0W40. So your oil changes will cost you a bit more than that as the oil will be closer to $7 a quart and the fleece filter up in the $15 range.
Bottom line, follow your owner's manual recommendations and your car will be much happier for it.
Take care and enjoy the ride,
Greg
Check Codes is offline
FS: Mann air filter, Mahle oil filter for 3.2 V6 (E320, etc) ashman78 For Sale/Wanted/Trade/Giveaway 2 10-18-2007 07:25 AM
C220 maintenance Q's (auto tranny fluid, filter) (oil viscosisty and filter) C220Heb W202 C-Class 4 03-20-2007 02:32 PM
torque numbers for oil drain plug & oil filter canister? ProV1x W210 E-Class 2 12-30-2006 12:41 PM
FS: 3.2 V6 (etc) OEM air filter, oil filter Mann, Mahle ashman78 For Sale/Wanted/Trade/Giveaway 2 06-26-2006 06:49 AM
Q: crossfire oil filter VS slk oil filter...same?? viken R170 SLK-Class 1 10-08-2003 07:19 PM
