What does "Lock Front Passenger Seat" mean? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 11-03-2007, 08:27 PM Thread Starter
Date registered: Jul 2006
Vehicle: 2003 Mercedes CLK320
Quoted: 2 Post(s)
This is what it says on the car screen. I did have to move the passenger seat up because I was putting something in the back seat. I did "fix" the passenger seat and "lock it in to place" or into position, I heard a click and everything. Why does it still say "lock passenger seat" even after I restart the car? It's not talking about the door btw, only the seat. At first I thought it was the door and re-shut the door but that's not it. And I did put the seat back "as far as I can tell".
Am I supposed to press some special button to "lock it"??
jackie100 is offline
post #2 of 10 (permalink) Old 11-03-2007, 08:47 PM
Bigraven's Avatar
Date registered: Oct 2007
What model Benz?
You may have popped the seat off of its track. Does the seat wiggle around, or can you still move the seat back and forth with the buttons on the door?
1961 Chevy Impala Bubbletop (restored) - SOLD
2000 Mercedes E320
The whole problem with the world is that fools and fanatics are always so certain of themselves, but the wise so full of doubts.
Bigraven is offline
post #3 of 10 (permalink) Old 11-03-2007, 11:57 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Guessing from previous posts it could be a 208. If so, does it have memory seats?
You said you tried the door but did you try the seat? Release the back rest and fold it back to position again.
Diesel Benz is offline
post #4 of 10 (permalink) Old 11-04-2007, 12:31 AM
Date registered: Jun 2007
Vehicle: CLK 220CDi
Try sitting on the seat, sometimes putting it back is not enough, although it looks as if you have put it back to its original position, you need some weight on it for the sensor to confirm.
Russ
CLK220CDi
Avantgarde
rf065 is offline
post #5 of 10 (permalink) Old 11-04-2007, 01:59 AM Thread Starter
Quoted: 2 Post(s)
Its a CLK 320
post #6 of 10 (permalink) Old 11-04-2007, 01:01 AM Thread Starter
Quoted: 2 Post(s)
I'll try your suggestions tomorrow. I can't right now cause it's cold and I don't want to walk to the garage. I didn't actually trying sitting in the passenger seat and then moving the seat back and forth. I'll try that tomorrow right away.
post #7 of 10 (permalink) Old 11-04-2007, 05:00 AM
Vehicle: CLK 220CDi
Mine does it frequently, sitting on it always clears the warning.
Russ
CLK220CDi
Avantgarde
rf065 is offline
post #8 of 10 (permalink) Old 11-04-2007, 11:04 PM
Vehicle: 02 CLK 430
Hello, If the seat is all the way back and locked into place, most likely, the switch that is triggered when the seat is in it's locked position has failed and the switch is not recognizing the fact that the seat is locked into place. There may be a problem with it and may need to be replaced.
mbzex.com is offline
post #9 of 10 (permalink) Old 11-06-2007, 06:43 PM
Peteski's Avatar
Date registered: Dec 2003
Vehicle: 2004 CL500 2008 ML320CDI
That was the problem - the switch - in my CL. Hope it's under warranty...
"Someday you will die somehow and something's gonna steal your carbon."
Peteski is offline
post #10 of 10 (permalink) Old 11-09-2007, 05:09 AM Thread Starter
Quoted: 2 Post(s)
Thanks everyone, I sat in the seat and adjusted the seat a bit with the memory buttons and everything is fine now.
    Can car (2003) be programmed to "chirp" for door lock/unlock? DaveS R170 SLK-Class 9 03-21-2011 06:33 AM
    WTB: Fog Lamp (passenger side) for 2002 CLK 430 "AMG" kgantzer For Sale/Wanted/Trade/Giveaway 0 09-10-2007 11:10 AM
    Passenger "Tilt-Down" Mirror in Reverse organist88 W164 M-Class 23 06-14-2007 07:19 AM
    TIRES WANTED!! 265/30/19 "rear" 235/35/19 "front" bigjx76 W203 C-Class 0 08-05-2003 05:14 PM
