Computer Reset fixed limp mode.. should it be ok? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-29-2007, 07:37 PM Thread Starter
Date registered: Oct 2007
My 99 ML 320 went into limp mode a couple weeks ago. If I am correct that limp mode= Reverse 2nd and 3rd ??
When I took it into the shop, the mechanic told me I should have the computer reset before doing anything else. After doing so (charged only for 1 hour labor) the car has run as normal. Is this something that I should worry about as indication of a big problem, or is this a normal thing? He told me that he used to have his reset regularly and that it would be fine for 6 months to a year.
Thank for the help.
ml320driver is offline
post #2 of 4 (permalink) Old 10-29-2007, 11:11 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
He did not tell which fault codes existed? The first assumption should be that there is something wrong in the car that needs to be fixed, if nothing else, then a malfunction in the self diagnosis. Some random faults might be OK to be just cleared but even there it is an inconvenience, if it can happen again after 6 months, it can happen the day after too.
If you did not get the fault codes this time, next time ask those printed first and post them here for experts' comments.
Diesel Benz is offline
post #3 of 4 (permalink) Old 10-30-2007, 01:53 PM Thread Starter
Thanks.
Fault code:
RPM/Speed Sensor #3 Faulty Y3/6n3
post #4 of 4 (permalink) Old 10-30-2007, 06:23 PM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
Thank for the help.
yeah thats the valve body speed sensor. there is def a problem and i'll bet ya that your contact plate is garbage. you shouldnt have to reset a modual once or twice a year anyways i would have someone check out that speed sensor with actual values. most of the time they read 8000 mph wich overiously is not right. its not to bad of a job to do yourself,let me know the outcome and i can pm you detailed instruction. good luck
mike
"MERCEDES BENZ LIKE NO OTHER"
ctbenztech is offline
    ITS FIXED........Limp home mode no more/transmission silverslk R170 SLK-Class 6 07-05-2011 06:03 PM
    LIMP MODE djblu R129 SL-Class 12 08-14-2007 05:21 PM
    HELP!! .. limp mode! BenzSLK230 R170 SLK-Class 7 06-12-2006 09:23 AM
    limp mode??? Dolphin27 R170 SLK-Class 1 01-04-2006 03:02 PM
    How to reset electrical limp mode? AceCal W210 E-Class 0 12-01-2005 01:32 PM
