Can a W124 run w/o Air Pump? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-28-2007, 09:40 AM Thread Starter
Date registered: Aug 2007
Vehicle: Cayenne, 300E
During a long drive from MA to NY, My Air pump came lose and started hitting the radiator.
My Mechanic told me he can remove it and run the engine w/o the air pump..since the part and labor will run me into 1K+ , it can this is the cheapest way...
he plans to run a smaller belt that doesn't go over the air pump wheel.
He said air pump is only used for the exhaust system..
Is he right? Is this safe to do? Opinions?
joeygambino is offline
post #2 of 4 (permalink) Old 10-28-2007, 03:44 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Without the air pump, the converter won’t be able lower the HC or CO levels as it normally does. Eventually you'll need a new cat as well. Aside from being illegal, removing the air pump *may* result in you failing the sniffer part of a smog test. If this car was in California, you’d fail the visual as well.
If your pump is broken, a rebuilt pump is $300. The two air valves are $15 each. Those are retail prices for a 91 300E (I have no idea what year your car is).
Rather than tossing the air pump, I'd get a second opinion.
MarcusF is offline
post #3 of 4 (permalink) Old 10-28-2007, 05:40 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Yes, you can run without an air pump except (1) I doubt your mechanic's ability to supply a proper belt without one, and (2) you'll never skate past an emissions test that way.
GeeS is offline
post #4 of 4 (permalink) Old 10-29-2007, 03:18 PM
johnhef's Avatar
Date registered: Mar 2007
Vehicle: Too Many
Send a message via AIM to johnhef
you may only need a clutch, which i believe is available but to get you home, remove it and try to find a shorter belt. no harm will be done assuming he can get it done.
Master Certified 10 years MB tech
1980 500SE Euro
1981 500SEL Euro
1982 380SEL
1983 500SEC Euro
1983 300TD
1984 500SEC - parts car
1984 300TD Euro
1985 190E 2.3-16 Euro
1986 190E 2.3-16
1986 190E 2.3-16 Lemons
1987 300D
1999 C230K
2003 C320T-4
2003 E55
johnhef is offline
    Fuel Pump relay do not run Mercedesbenznl W126 S,SE,SEC,SEL,SD,SDL Class 7 05-26-2007 08:19 AM
    Air pump_Anyone got front cover or complete air pump for sell Jarekjp R171 SLK-Class 0 03-05-2006 12:46 PM
    Air Con - How often to run it in winter? Andy747 R171 SLK-Class 5 12-10-2005 06:43 AM
    water pump over run digio W163 M-Class 2 10-05-2005 01:36 AM
    Do W124 300's run hot? RGubbioli W124 E,CE,D,TD Class 17 09-14-2005 05:50 PM
