ABC Error - Now Noise - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-24-2007, 04:13 AM Thread Starter
Date registered: Apr 2004
2001 - S500
This week I got a "Active Body Control - Drive Carefully" message. After restarting the car the message disappeared, but now I have this noise coming from the front side of the car. It sounds like a moaning noise (hard to describe). There is no leakage under the car and the car has not dropped. The message has never reappeared only the noise remains. Could it be the Hydraulic pump? (Is it called a Hydraulic pump or ABC pump or Power Steering Pump). Is there anywhere I can check the fluid or add fluid? Reset something?
Last thing right before I got the error message I had the right side (front and back tires) of the car parked on a small curb because of a narrow street. Could this have anything to do with this problem?
didonato is offline
post #2 of 2 (permalink) Old 10-24-2007, 03:08 PM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
there should be a dipstick on the left side of the car, it needs to be check with the car running. this is you p/s pump and suspension pump. ive replaced them many times. they are not easy to do. as a seinor tech it takes me about 3 hours. ac lines have to come off evac/ charge. there a 2 bolts behind the pump out of sight. it's really not a diy job.
ctbenztech is offline
    ABC/PS pump leaking causing ABC suspension severe drop 2003 s600 W220 S-Class 16 07-03-2012 03:54 PM
    ABC Error - now noise didonato W220 S-Class 1 10-24-2007 12:53 PM
    Abc tanmervin R230 SL-Class 4 09-17-2006 10:56 AM
    abc lnguyenh Test 0 09-13-2005 05:50 AM
    abc lnguyenh Test 4 10-09-2004 01:35 PM
