96 C280 will not start - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-14-2007, 04:32 PM Thread Starter
Date registered: Oct 2007
I am in need of some major help!
I recently replaced the head gasket on my 96 C280 and put it all back together, the car started first time and ran fine, I drove it around the block, everything was working great. Sat idling, looking for leaks and it just stopped. Took a long time of cranking to restart and ran fine - sat idling again and then it stopped again. Tried everything and it won't start. It will crank with the motor turning over, it has fuel to the rail. But will not fire off. Any ideas?
Any help will be much appreciated.
Thanks
merc280 is offline
post #2 of 2 (permalink) Old 10-15-2007, 05:49 AM
Date registered: Mar 2006
Vehicle: 1996 Silver C36
My guess would be Crankshaft Position/Angle Sensor or one of the three Coils. Check the connections first. After that, I would worry about internal breakdown of the insulating material inside the engine wire harness, especially in the areas that are subject to the most engine heat.
Good luck!
OzC36 is offline
1998 C280 Won't Start Intermittently captainron W202 C-Class 31 08-17-2011 04:08 PM
2000 C280 Won't Start. oledale General Mercedes-Benz 4 04-03-2007 10:24 AM
94 C280 won't start pguard W202 C-Class 9 12-28-2006 04:21 PM
1998 C280 Won't Start Intermittently captainron W203 C-Class 2 01-23-2005 12:38 PM
C280 will not start after engine is warm?? MAC10 W202 C-Class 1 12-24-2002 02:36 PM
