Looking for info about buying a 300TD wagon years '80-'87 - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 10-11-2007, 09:01 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
DDR makes for Deutchland Democratic Republic. I wonder if the last owner come from there.
Non-turbo diesel (listed as gasoline) with 86 HP is not going to make a rocket, but still decent buy if you can get it below $3000
Kajtek1 is online now
post #12 of 16 (permalink) Old 10-11-2007, 10:40 PM
Date registered: Sep 2007
Vehicle: 1999 MB ML 430 (current) Passed: 1999 MB E430 sport
I think for this year Mercedes
It's worthy no more than 1k5, given that the car runs good
just my opinion
echaocn is offline
post #13 of 16 (permalink) Old 10-12-2007, 05:45 PM
Bigraven's Avatar
Date registered: Oct 2007
You're making the right choice in car, I'll give you that. I snagged my '87 300TD for 1k. No rust, no paint bubbles, flawless interior, 85,000 miles, it just would not start. The previous owner said that he left it running outside in 70 degree weather when the car just shut down on him. I took it to my Mercedes specialist and he found out that one of cylinders was jammed, fixed that; now I'm rollin' the streets again and got it to 100,000+ miles. Just change the oil every 3k miles and you're just chuggin' along. The benz I have is really like a tank, the engine just goes. No problems in the winter either. I don't have to plug it in.
1961 Chevy Impala Bubbletop (restored) - SOLD
2000 Mercedes E320
The whole problem with the world is that fools and fanatics are always so certain of themselves, but the wise so full of doubts.
Bigraven is offline
post #14 of 16 (permalink) Old 10-14-2007, 06:20 AM
Mike Wevrick's Avatar
Date registered: Oct 2006
Vehicle: 2003 S500 4MATIC
Have you seen this? eBay Motors: Mercedes-Benz : 300-Series (item 140168134130 end time Oct-20-07 11:52:12 PDT)
Ironically the car was shipped up from Florida, but air tickets up here are fairly cheap.
Mike Wevrick is offline
post #15 of 16 (permalink) Old 01-14-2009, 03:36 AM
Date registered: Dec 2008
1979 and 1980 wagons were both non turbo units and have a climate control system that is often expensive to repair (if taken to the wrong mechanic.)
w123benzman is offline
post #16 of 16 (permalink) Old 11-21-2010, 01:19 AM
Date registered: Nov 2010
Originally Posted by passporte View Post
Hi Everyone...I am really open to all suggestions anyone can offer about 300TD wagons years '80-'87...I hope to eventually convert the engine to run on alternative fuel sources.
Its my understanding that you actually convert the fuel, not the engine.
You see, Rudolph Diesel, the inventor of the engine from whom the engine takes its name, didn't design his engine to run on Petroleum-based products, but rather, on Peanut Oil.
In those days, petroleum based oils, such as Gasoline, weren't very common and he wanted to design something that would run on an easily obtainable fuel source...so why not something that could be found in most kitchens?
You could even run the engine on whale oil, which was a common fuel of the time (for lamps).
The engine was actually modified so that it would run better on petroleum based oils, later on in its development, since the otto-mobile was becoming somewhat of a world wide sensation.
Thus, going back to cooking oil, as an alternative fuel source, isn't really that much of a stretch for a diesel engine.
The only problem is that the sugars present in most cooking oils can foul the injector and injector pump, which is literally the beating heart of the Diesel engine, thus one must remove those sugars, in order to be able to use the oil on anything approaching a permanent basis.
There is (or used to be, anyway) a large "still" that one could buy, that would remove those sugars (and other impurities) from used cooking oil.
It was quite effective, although the $2500 selling price (minus shipping, handling and any taxes that may apply) might be a bit steep for some.
Wanna see the process in action?
Check Youtube, or maybe Discovery's website, for the first episode of a show called "Dirty Jobs".
Mike Rowe's very first, ever, "Dirty Job" was to convert used cooking oil into a fuel that could be burned in a diesel engine.
The still that guy uses is the one I'm referring to here.
Stacey David also did a feature on it, on that "Trucks" show he used to do on TNN (or whatever they call it now), a few years ago.
However, you can use cooking oil, straight out of the bottle (or pan) in your car and it'll burn just fine.
I would NOT recommend long term usage like that, but in a pinch, it just might help you get home.
Just remember to filter the stuff as you pour it in.
They proved that on Mythbusters, when they took used cooling oil, and sifted it through several large coffee filters and straight into a bottle which was fitted to the fuel line (doing a milage test to see if one could actually run a diesel powered car on used cooking oil - and of course, the guinea pig was a 300D ).
Granted, they only used one measured gallon, but the car did run, although milage was down slightly.
But getting back on subject, the point of this (now) overly long reply is that one doesn't refit the engine to run on the cooking oil. One "refits" the oil, so that it can be safely used in the engine.
...and yet, there's still some concerns about lubrication (the fuel actually lubrcates the injection pump and injectors), so you still might want to blend in some actual "diesel fuel" (maybe 5-10%, by volume), so a fuel blender wouldn't be a bad investment, either.
It might seem a bit "poo-poo" to incorporate the very thing you're trying to eliminate, but look at it from the other side, you're still eliminating about 90-95% of the thing you're trying to get rid of.
Anyway, hope you found this information to be of use.
DeanMk is offline
    Thinking about buying a 1987 300TD wagon Skeeter W124 E,CE,D,TD Class 3 01-05-2006 06:55 AM
    Thinking of buying '81 300TD Wagon jrehm W123 E,CE,D,CD,TD,TE Class 12 08-15-2004 10:38 PM
    Considering buying '81 300TD Turbo Wagon jrehm W124 E,CE,D,TD Class 2 08-13-2004 01:41 PM
    Buying a 300TD /TDT Wagon (tips + equipment codes) Bernard W124 E,CE,D,TD Class 3 10-03-2002 12:52 PM
    buying a 1983 300td wagon? Guest (MBNZ) General Mercedes-Benz 2 07-24-2002 05:38 AM
