Is it possible that a bad dealer put bad/old parts on cars under warrenty? - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 10-07-2007, 10:48 PM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Originally Posted by Punjabi View Post
Some Dealerships are actually owned by the respective car manufacturer and some are under 'franchise'. Those owned are generally very 'tight' on unnecessary replacement under Warranty but the 'Franchise' ones are more flexible and will tend to replace 'over and above' under the Warranty period. This is quite prevailent in the UK but may differ in the US.
Even those shops that are not owned by MB, are these days strict on replacing parts (If a part was replaced while it turns out to be good, MB usually refrains paying for it, the shop would have to pay for it). But that would not mean they would put a used or bad part to a car under warranty.
If an official dealer service replaces a part for a car under warranty, they would use new parts. Otherwise it would be some service guy acting against their rules, like said, anything can happen but it should be uttermost unlikely and a misbehaving service person would get caught soon.
Diesel Benz is online now
post #12 of 20 (permalink) Old 10-08-2007, 05:52 AM
mybenz123's Avatar
Vehicle: w123 300tdt
Originally Posted by zhuorongdeng View Post
Is there a case that the dealer even put some bad/old parts on cars under warrenty to let you come back more often so that they can charge more? (unfortunatly, it has been too many things wrong for my new car Thanks.
How old could those parts be?
Serious now, this is a New car not a used one.
Now if I go for parts for my 1984 300tdt I'm sure
that not all parts are "brand new" but they work
perfectly fine.
You probably have a lemon and you should take
the proper steps to deal with those problems.
Just my 0.02.
Louis.
mybenz123 is offline
post #13 of 20 (permalink) Old 10-08-2007, 02:55 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
In the United States, I believe the only dealership owned by Mercedes-Benz USA is Mercedes-Benz of Manhattan (New York).
At Porsche, parts exchanged under warrantee are sent back to PCNA. Expensive parts are regularly tested. If an expensive part is warranteed, and that part is found to be functioning as designed, the dealer gets to eat the cost. I believe MBUSA has the same policy. I've been told that if an engine is warranteed, it will be checked. If the engine is good, the dealer eats it.
MarcusF is offline
post #14 of 20 (permalink) Old 10-08-2007, 06:56 PM Thread Starter
Date registered: Oct 2006
Vehicle: 2006 C230 sport
I live in NYC, so I think I better have my car serviced in MB Manhattan then;.
This is exactly my point! As I stated in my ealier post, they (if they did) usually did something to the parts that are inexpensive and winout a S/N to track whether it is from a particular car, like bearings, ideler pulleys, etc. They akso knows how to fix it right the way.
Anyway, I think I just need to use my sense to select which dealer I should work with. I visted 4 dealers so far, and msot of them are nice, but there is one that I have concern with, no (and impossible to) prove though.
Thanks for all the reply.
zhuorongdeng is offline
post #15 of 20 (permalink) Old 11-01-2007, 11:13 PM
Date registered: Sep 2007
Vehicle: MB ML350 '07
I find it interesting that people are so quick to question your mental state or label you as paranoid when you question someone else's interigty. Is it easier to believe zhuorongdeng is crazy than it is to believe the dealer is unscrupulous? I happen to agree with Z. If you suspect something untoward is going on, it probably is. Unfortunately there isn't always a way to prove what you suspect. I think nanny cams have proved that too often people behave badly when they think they are not being watched.
Benzo350 is offline
post #16 of 20 (permalink) Old 11-09-2010, 08:23 AM Thread Starter
Believe or not, I just found that the hummidity dew point sensor (the one behide cabin air filter) is missing in my 2006 C230. I confirmed it with the parts department of the current dealer, and has to order it in my own cost. I reported it to MB USA, hope they can improve on this.
I don't know how and when it is missing. The SA in the dealer said the star dignosis does not report any problem (with a sensor missing, should I believe them?). As I said earlier, I have some many visits to differnet dealers (only dealers working on the car out of my eyesight), I cannot say who is the bad guy or if it is done with intension or not. Anyway, just the fact.
post #17 of 20 (permalink) Old 11-09-2010, 09:04 AM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1348 Post(s)
The conspiracy theory goes pretty far, but I read hundreds of times, when mechanic working on one part under the hood breaks electrical connector on other, that mask it with electrical tape, what brings problem some time later. Leaving bolts without proper torquing is just too common. Than on several used cars I bought the oil filters were extra crispy. I wonder how many oil changes the same filter survived?
That said, our original 12 years old ML320 is the most perfect car I have heard about.
12 years took only about $300 in needed parts on the model that was called a lemon by lot of owners relying on dealers.
Shall I mention that besides couple warranty glitches and recalls no mechanic put his finger on the car?
Kajtek1 is offline
post #18 of 20 (permalink) Old 11-09-2010, 09:04 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Is there a case that the dealer even put some bad/old parts on cars under warrenty to let you come back more often so that they can charge more? I have a doubt about my services from one dealer ...
Yes, I know that dealer.
Saw him on the "grassy knoll" in Dallas in 1963.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #19 of 20 (permalink) Old 11-09-2010, 11:14 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
"Is it possible that a bad dealer put bad/old parts on cars under warrenty?"
To sleep well while my beloved car is at the dealer for service, I would buy a silver ink permanent marker, mark my name, "mbvis", on every replaceable part in the engine compartment except the engine mounts before I hand my beloved car to them.
mbvis is offline
post #20 of 20 (permalink) Old 11-09-2010, 01:30 PM
Kajtek1's Avatar
That is exactly what couple investigative reporters did with computers given for repairs.
Almost, since they used markers visible only under ultraviolet light.
So after taking the computer to the repair shop and paying for new hard drive, they took it home and under the uv light did found their marker on HD. You can find the clip on youtube. Another one is about transmission flush.
I bet the trick would work on several computer chips on Mercedes as well.
Kajtek1 is offline
Bad bad bad problem today... quaznizi4 W203 C32 AMG, C55 AMG 21 03-18-2008 01:36 AM
Bad Ass Cars ! DJ-ZIPPY Off-Topic 2 07-15-2007 03:11 PM
Dealer problems? Rate your dealer, good or bad!! reallife C219 CLS-Class 0 08-23-2005 03:36 PM
Bad ideea to put 235/45 tyres on 16" ? EUCLK200 C208/A208 CLK-Class 4 03-22-2005 11:55 AM
when good cars have bad owners andrewgclifford W124 E,CE,D,TD Class 7 08-08-2003 01:21 AM
