turn signal problem any advice welcome - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-02-2007, 11:37 AM Thread Starter
Date registered: Oct 2007
Unhappy turn signal problem any advice welcome
I recently bumped my turn signal indicator with my knee getting into my car and now the blinker is alway on indicating that I'm turning left. If I click it to turn right it blinks the right light but after I make the turn it clicks back to bilnking left. There is no shutting it off in the middle position. It's always on. Makes it very difficult for other drivers seeing my car on the road blinking away. Anybody have this issue ever? Thanks
keith hagen is offline
post #2 of 5 (permalink) Old 10-02-2007, 12:04 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Model and year?
I had a ML320 that would click over to the right turn signal after I made a left hand turn, but not ever having the signal on all the time. I can only assume that you broke something in the column. Once you post the model, someone may be able to tell you how to take it apart.
Mike
Michael Pillay is offline
post #3 of 5 (permalink) Old 10-02-2007, 02:20 PM Thread Starter
blinker problem
it's a 2000 E320 thanks
post #4 of 5 (permalink) Old 10-02-2007, 05:33 PM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
you need a blinker stalk. very easy to replace your self, if you have any mech abillities(sp). its a common problem on the 210's.
mike
"MERCEDES BENZ LIKE NO OTHER"
ctbenztech is offline
post #5 of 5 (permalink) Old 10-02-2007, 08:13 PM Thread Starter
Thank you I'm somewhat mechanical...I guess I'll check with a shop as to what exactly I should do.
    Turn Signal Problem ERFOY R170 SLK-Class 5 07-30-2008 07:31 AM
    turn signal problem santino57 W210 E-Class 7 10-03-2007 02:49 PM
    turn signal problem! xx7sephiroth7xx W140 S-Class 7 11-13-2006 05:42 PM
    turn signal problem jsl@gorge.net W123 E,CE,D,CD,TD,TE Class 13 06-13-2006 08:30 AM
    Turn Signal Problem Studrat R170 SLK-Class 4 06-24-2003 08:40 AM
