300D EGR DISABLING - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-26-2007, 05:28 PM Thread Starter
Date registered: Sep 2007
Vehicle: Meleady Jr
Question 300D EGR DISABLING
What are the downsides of disabling the EGR? We have one on our VW diesel and it's nothing but a pain in the intake!
dezell dog is offline
post #2 of 4 (permalink) Old 09-26-2007, 06:51 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
nothing other than the exhaust will not be as clean. The good thing is that you car will gain a few more HP and will pick up speed better. Come on over to the W123 section.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #3 of 4 (permalink) Old 09-27-2007, 01:28 PM
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Just make sure you don't show up in Cali.
mlfun is offline
post #4 of 4 (permalink) Old 09-27-2007, 10:00 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
An older 300D should not have problems of the same type a VW TDI has with its EGR if its working correctly.
Avoiding the Need for Intake Manifold Cleaning - Recalibrating the EGR System: VW TDI 1998 through 2004 North American Models
This vehicle is equipped with a CCV (crankcase vent) system and an EGR (exhaust gas recirculation) system. Oily fumes from the CCV system can combine with carbon particles from the EGR system to form a black sticky tar in the intake system. This eventually starts restricting the amount of airflow into the engine, resulting in gradual power loss as the vehicle ages and the intake clogging becomes worse. In rare cases a MIL ("check engine" light) may be tripped, with an intake manifold pressure control code set, but normally this does not happen and no codes are set. Operating conditions, fuel quality, oil quality, driving habits, and general condition of the engine all have some effect on how long the intake system survives before clogging up. It can be prevented and this recalibration is highly recommended for all TDI owners.
A VW specific scan tool such as VAG-COM is required for this procedure. With the engine warmed up and running at idle in neutral with all major accessories such as air conditioning turned off, connect the scan tool cable and start the scan tool software. Select engine control module. "Login" using 12233 as the access code. Select "adaptation" and go to adaptation block 3. Give the accelerator pedal a quick "blip" to ensure that the EGR remains turned on for the next minute while you perform the following steps. Note that the display shows a default adaptation value of 32768 and shows approximately 250 +/- 20 mg/stroke of air intake volume. (If it does not show this, you are either on the wrong screen, or you have an older ECU that differs slightly - see next paragraph.) If all is well, enter 33768 as the new adaptation value, and select "test". Note that the displayed air intake volume changes, usually to about 370 mg/stroke. The specification limit is 370 mg/stroke, so if you want to remain within OEM shop manual specifications for emission control reasons, you might have to enter a number slightly smaller than 33768. (If you don't care about road-legal NOx emission limits then leave it at 33768. [Depending on the usage cycle, NOx at this setting can be increased by as much as 40%]) If all is well and you have a seting that you are happy with which results in an intake air volume of 370 mg/stroke or just a hair less, enter "save". Now your intake manifold either will never clog, or will take so long that the engine will wear out first.
Note for '96 Passat and possibly other older ECU variations: The adaptation numbers are in a different range, and you won't be able to get feedback on what you are doing on the same screen. The EGR adaptation number for a '96 Passat with the original "BK" ECU is 188 rather than 33768 and you'll have to go back to "measuring blocks" group 3 to see the effect before "saving" the new setting.As for warranty, no one has mentioned any problems nor should there be. This adjustment is also completely reversable should one be concerned.Most provinces and states that do emissions testing on diesels, just check opacity, so this will not be a factor when testing.
VAG-Com is a hardware/software solution that duplicates the function of VW factory diagnostic equipment and gives the owner of a VAG product the ability to access the diagnostic and adaption channels of the vehicle in ways that would require a full kit of STAR if the vehicle was a MB. For VW's this product is under $250.
As with ALL European Diesels, always try to use LSD diesel fuel. The lower sulpher content reduces the amount of solid particulates in the exhaust and helps to keep your engines internal parts cleaner as well.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
    removing egr tube from egr valve....benefit brandon671 W126 S,SE,SEC,SEL,SD,SDL Class 16 07-19-2012 05:38 PM
    Disabling ESP haister W210 E50 AMG, E55 AMG 5 10-05-2006 11:53 AM
    Does 1984 380SL have an EGR/EGR Filter? ericgr R/C107 SL/SLC Class 2 08-15-2004 02:39 PM
    Disabling Alarm gallian W124 E,CE,D,TD Class 1 04-27-2004 06:34 PM
    Disabling sensors Kzin W123 E,CE,D,CD,TD,TE Class 0 11-19-2002 08:08 AM
