Diesel presure seal leak, air in filter, no start - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-21-2007, 05:48 PM Thread Starter
Date registered: Sep 2007
Vehicle: 2000 ml430, 2000 C230 Komp, 2004 ml500
I read the forum on leaky seals on top of the injection pump. Would these leaks lead to air in the filter and thereby no pressure to the injectors? If I park with the nose down by 20 cm from the rear, the car starts every time. If I park level or God forbid the nose up, the car will not start unless I bleed the fuel system. My o rings are showing some weepage, but that is the only leak I see. The car is a 1987 station wagon in A-1 shape. The engine has 147,000 and has used bio for two years.
solywoda is offline
post #2 of 2 (permalink) Old 09-21-2007, 06:49 PM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
yeah this will cause air in the line creating a hard/no start
ctbenztech is offline
    Diesel presuure seal leak, air in filter, no start solywoda General Mercedes-Benz 0 09-21-2007 05:47 PM
    diesel wont start after fuel lines and filter change biodieseler W210 E-Class 6 10-29-2006 07:10 PM
    WANTED: California Diesel Air Filter Assembly donniej W123 E,CE,D,CD,TD,TE Class 4 05-11-2006 08:46 AM
    Engine air filter and cabin air filter life tempoct R170 SLK-Class 2 05-03-2005 09:01 PM
    Air leak in diesel fuel lines C250d or E250D JOHNWOLFM General Mercedes-Benz 0 12-12-2004 01:31 PM
