R230 AMG III fit wheels on w140 CL600? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-19-2007, 12:51 AM Thread Starter
Date registered: Jun 2007
I have a w140 CL600 and picked up a set of 18" AMG II wheels ET30 and ET33. What do I need to make these fit correctly? Only new lug bolts? What size bolts?
A230 401 20 02 ET30
A230 401 21 02 ET33
fjo009 is offline
post #2 of 2 (permalink) Old 10-03-2007, 10:31 AM
gumsie's Avatar
Date registered: May 2005
Vehicle: '96 500SEC + 2011 C350CDI
Quoted: 6 Post(s)
Send a message via AIM to gumsie
I would suggest not. The standard offset for the 7.5Jx16 wheel is 51mm and for the larger 8.5 and 9.5x18 and 19 inch wheels it should be around 44-47mm.
That 30 that you have there is very low. I'm assuming the wheel is a wide one and if that's the case it will rub on the outer arch, as the lower the offset it has the effect of pushing the wheels out, away from the car.
You might also get problems with tramlining and suspension components wearing prematurely due to what amounts to a large change in the geometry.
gumsie is offline
    FS: 20” TSW THRUXTON wheels and tires staggered fit W211, R230, W220, W163, W215 Gmotoring For Sale/Wanted/Trade/Giveaway 2 10-15-2006 03:40 PM
    Are AMG styling III wheels (8,5j x 18 Lk 5x112 ET30) compatible with w140 cars???? jvallet W140 S-Class 6 05-14-2005 10:51 PM
    Does anyone know if the new AMG SL R230 rims fit on a C240? Guest (MBNZ) W203 C-Class 0 07-19-2002 01:17 AM
    WILL BRABUS MONOBLOCK III WHEELS FIT MY CAR Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-13-2002 10:01 PM
    New AMG wheels for the R230 SL... Brian R170 SLK-Class 0 10-10-2001 05:46 PM
