Engine Misfire - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 09-11-2007, 07:25 AM Thread Starter
hofkamp83's Avatar
Date registered: Apr 2007
Vehicle: 2002 C32 AMG
from the first i brought it in, i don't know the exact codes, but said there was a misfire on cylindars 1, 2, 3, and 5. The check engine light was on and flashing when it was running rough, but on this last time the check engine light came on and flashed when it was running rough but then the check engine light went it off the next time i turned it off.
I am currently away from my car for awhile and will bring it in when i get back
Andrew
2002 C32
hofkamp83 is offline
post #12 of 14 (permalink) Old 09-11-2007, 12:12 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Andrew
2002 C32
The only time I had the check engine light flash was when I had misfires on one bank of cylinders. It turned out to be a clogged catalytic converter. I thought you might have the same problem, but the misfire on 5 does not make sense then. Maybe you do have a clogged cat and the coil on 5 is bad.
Mike
Michael Pillay is online now
post #13 of 14 (permalink) Old 09-11-2007, 10:23 PM
Vehicle: Volvo 940GLE, GMC Suburban, Infiniti I30, Toyota Prius, VW GTI, MB SLK350, Lexus IS250
Generally speaking, the probability of two failures happening at the same time is pretty rare. But it seems your explanation is the most plausible.
It is unlikely 87/89 octane gas will cause rough idle. May be pre-ignition but not rough idle.
CalifSLK is offline
post #14 of 14 (permalink) Old 09-20-2007, 07:17 PM Thread Starter
hofkamp83's Avatar
i got the car back from a different dealership and again they couldn't find anything wrong, said the cat is fine, maf is working properly, and coils are good. They couldn't get it to repeat at the shop so they didn't replace anything so again i spent a couple hundred dollars for them to do nothing.
Well this pissed me off so much that i went and sold the car and bought a jap truck no more benz's for me, i assumed the benz's tech's knows what they are doing but no, and the dealerships just seem to want you money, for everybody else just be warned
Andrew
had 2002 C32
2005 Toyota Tundra Limited
    C180 - Engine Misfire / Backfire Wully_UK W202 C-Class 4 10-03-2015 09:11 AM
    Engine Misfire ranjitsml320 W163 M-Class 11 09-23-2007 11:11 PM
    how can I diagnos my engine misfire?? skipinschool W140 S-Class 12 09-07-2007 09:22 AM
    Help with engine misfire codes johnny63ml320 W163 M-Class 15 11-14-2006 06:52 PM
    300SD: engine misfire aadix W126 S,SE,SEC,SEL,SD,SDL Class 6 12-04-2004 09:29 PM
